Lip Seals/O ring calipers?
Old Nov 12, 2006 | 11:46 AM
redvetracr's Avatar
redvetracr
Originally Posted by Jud Chapin
A similar question; does the o-ring set up use standard pistions?
NO, it uses a piston cut for a round o-ring.
...redvetracr
Old Nov 12, 2006 | 11:52 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
...redvetracr
Thanks for the input!
Old Nov 12, 2006 | 11:56 AM
Restorod '79's Avatar
Restorod '79
http://www.fastcorvette.com/Brakes.htm
Interesting reading on calipers.
Scroll down and click on caliper school. Also some info on seals below that. ( Info provided by sales dept. )
Old Nov 12, 2006 | 12:04 PM
...Roger...'s Avatar
...Roger...
...redvetracr
Thats what I was waiting to hear.Special piston and a round O-ring not square or flat.Is the groove in the piston round at the bottom or is there something special like a taper? It seems like it would just match the contour of the O-ring.Also you said no spring with that piston-is the piston too long?
Old Nov 12, 2006 | 12:31 PM
dads69's Avatar
dads69
7th Gear
You Might want to check this out before you make a decision
http://www.fastcorvette.com/CaliperSchool.htm
Old Nov 12, 2006 | 12:34 PM
Jud Chapin's Avatar
Jud Chapin
Good article!
Old Nov 12, 2006 | 01:31 PM
...Roger...
I dont think this artical is comparing apples to apples.I think Duntov was refering to the square o-ring design used in the outside of the bore.I cant see where the new o-ring design would not allow a little bit of piston face deflection.I havnt seen the new pistons but if they are so long that they can not "wobble' in the bore then that might be a problem.The face of the piston does have to angle at times.
