What causes column slack?
I hit a pothole with my truck and it started doing exactly what you're explaining. I could't figure out what was going on... but I finally noticed that the gearbox was torn right out of the frame, and only staying put because it had nowhere to go. But when I turned the wheel you could see it rock.
I have a series of three papers that can be found at www.corvettefaq.com in the Jim Shea's Steering Papers section. (You then need to click on Corvette Steering Papers and scroll down to the Tilt & Telescoping 69-82 areas. The papers are as follows.
#1 Test strg column and minor disassembly (column still in the car).
#2 Drop column, remove from car, replace ignition switch.
#3 Disassemble upper end of column, remove steering shaft.
I would suggest that you download paper #1 and conduct the quick tests to identify any other problem areas in your steering column. Bad upper bearings could allow some movement of the upper steering shaft that might seem like lash.
Assuming that you are sure that the problem is in the steering shaft, there is only one obvious place that it can be occuring in a T&T column. There is a two piece plastic sphere the allows your column to tilt.
If the problem is indeed in you steering shaft here is some background:
The upper steering shaft (the part that tilts) and the lower steering shaft (extending from the plastic ball down and out into the engine compartment) both terminate with ends that form a semicircular yoke.
You must have developed lash between the yokes and the plastic spheres.
The good news is that the lash can be corrected by carefully "tonking" on the ears of the yokes with a hammer. The bad news is that the steering column has to be removed from the car and the steering shaft removed from the steering column in order to disassemble the steering shaft to be able to "tonk" the yoke ears. You will need the other two papers as well as the three Disassembly and Repair Pics that are in the same section.
Jim
