leaking power steering question
Old Sep 21, 2001 | 12:55 PM
Turbo-Jet's Avatar
Turbo-Jet
Default leaking power steering question
i noticed fluid leaking from my power steering lines underneath. other than the loss of power assist, is there any risk of mechanical damage if the fluid gets too low?
also, what component is most likely leaking? how hard to replace?
thanks
Old Sep 21, 2001 | 01:52 PM
gerry72's Avatar
gerry72
Default Re: leaking power steering question (Turbo-Jet)
The pump can burn-out from the lack of lubrication if it gets too low or goes dry. Other than the pump, nothing else. Of larger concern, Cam, is what happens to hydraulic oil when it comes into contact with hot stuff.
Old Sep 21, 2001 | 02:55 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: leaking power steering question (gerry72)
umm... nothing? JK, good point. next project...
Old Sep 21, 2001 | 03:05 PM
Biker's Avatar
Biker
As long as you keep the reservoir topped off, losing fluid will do more to damage your floor than the car.
Old Sep 21, 2001 | 03:37 PM
rdrman's Avatar
rdrman
Ussally the hoses are first to go.Worry if they go big time , your exhaustor n headers are not to far away,with the airflow pushing the oil that way,could give you a big suprise, in basicly a plastic car :seeya
Old Sep 21, 2001 | 04:29 PM
454Big's Avatar
454Big
Default Re: leaking power steering question (rdrman)
Don´t panic!!! :eek:
There is way to less oil in the pump reservoir to set the car on fire!
The surprise you talk of could only happen, if the oil is blown out at once and on the exhaust manifold - where the likelihood is against infinity that this happens.
Usually the flared fittings leak - especially when they have been loosened and tightened in any other position then.
I guess with 50 bucks for new lines the job will be done!
Always use power steering fluid! I once used ATF in mine - result: all ATF on the garage floor one morning.
I don´t know the reason for that, but I thought its worth to mention!
To leaking power steering question
