Aerodynamic suction device for a C3
Old Nov 10, 2006 | 03:27 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Aerodynamic suction device for a C3
I've been kicking the idea around for a little while of using fans to suck the air from under the car to create down force. The Chaparral 2J car used this concept in the early '70's and, more recently, the McLaren F1 super car has some sort of fan system. I haven’t run many numbers yet but the Chaparral used a 274cc two-stroke from a snowmobile to power two fans and the car was setup with aggressive skirts from just behind the front wheels running all the way to the back of the car. Much of this isn't practical for a street car but McLaren clearly made some compromises yet felt that it provided some advantage.
So I'm thinking that a 274cc two-stroke from the '70's would put out 20 or 30hp? That kind of power would be difficult to match in an electric driven fan so I wonder the power that McLaren spec'd for their fan? I think some moderate skirts would still be useful and practical for many driving situations. As I said I haven't run any numbers yet but I think calculating the total air volume running under the car at a specific speed and getting a general idea of the pressure is a good start. It really doesn't take much of a pressure differential to make some serious down force so I think the effort is worth it.
Old Nov 10, 2006 | 03:41 PM
kevinator80's Avatar
kevinator80
rock on brother.
Old Nov 10, 2006 | 03:53 PM
burners's Avatar
burners
Cruise-In V Veteran
Does anyone know a good source for some high output electric fans?
Old Nov 10, 2006 | 04:01 PM
Gordonm's Avatar
Gordonm
You would have to be doing somewhere over 100 mph for this to even make the slightest difference. Where are you going to mount these heavy "suckers"?
Old Nov 10, 2006 | 04:28 PM
The Spark's Avatar
The Spark
The Chaparral has a floating skirt all the way around the bottom of the body so it is in contact with the ground all the time.
All the Chaparral cars are on display at the Petroleum Museum in Midland, TX if you want to see them up close and personal (plug for the hometown )
At the grand opening of the Chaparral wing of the museum one of the drivers described driving the car...
When they started the engine for the fans you could feel the car go down a couple of inches.
He said it really stuck to the track and they were able to go around corners much faster than anyone else.
The Chaparrals were known to use aerodynamics such as wings and body shape to create downforce. This was a departure since it created downforce just sitting still.
Old Nov 10, 2006 | 04:34 PM
burners's Avatar
burners
Cruise-In V Veteran
That is, in fact, completely not true. If lightweight, efficient fans can be utilized the weight penalty may be something like 20 to 40 lbs. The effect will be useful in the 20mph+ range. I would add 40 lbs in a heartbeat if it gave me .2 more G cornering ability. I'm not sure about, say, 100 lbs for a .5 G increase but these numbers are theoretical at the moment.
The fans would have to be mounted somewere in the rear of the car. I don't run a spare tire so there is a lot of room under the gas tank.
Old Nov 10, 2006 | 04:35 PM
The Spark's Avatar
The Spark
I would think about using a front spoiler with a flexible skirt to get it low to the ground and possibly a skirt around the sides. The faster you drive you create low pressure under the car that will suck it down.
You will need to be going pretty fast for this to really be effective I would think. If you are driving autocross (from your picture) I don't think you'll get up to a high enough speed.
If you come up with a vacuum setup please post pics. That will be interesting to see.
BTW - they have / had an interesting display at the museum showing how much tighter a model car can turn using the vacuums.
Old Nov 10, 2006 | 04:38 PM
PRNDL's Avatar
PRNDL
Make sure to install them so they work both ways. There will be times when you will want to reverse the fans and use your vette as a hovercraft!
Old Nov 10, 2006 | 04:39 PM
burners's Avatar
burners
Cruise-In V Veteran
72vette_454, I'm hoping to visit the museum sometime. No offense but the Chaparrals and the CAF are the only reasons I would visit Midland. It's a long way from nothing out there. I may have a road trip to AZ and CA within the year so I may get a chance to stop by.
Old Nov 10, 2006 | 04:44 PM
burners's Avatar
burners
Cruise-In V Veteran
Actually, the beauty of a fan system is that it works much better at low speed than a conventional aero undertray which relies on air movement in order to generate down force. I mainly run track events but it would definitely work for autoX as well (it would just be illegal). That model car display sounds cool.
73C34me's Avatar
73C34me
i think the snowmobile engines were closer to 440 c.c. & 50 hp. I believe this is told in a biography on mark donahue (?)
Old Nov 10, 2006 | 04:45 PM
The Spark's Avatar
The Spark
No need to apologize. I grew up in Corpus Christi and have lived here for 15 years. I still miss the water! It is a long ways away from just about everything.
You need to come out here in October to the CAF airshow. They bring in lots of WWII warbirds and the show is awesome.
The good thing about living out here is there are plenty of open roads to drive. Going down to Big Bend area this weekend - great curves and mountains (that's what we call them anyways). Highest elevation is over 6,000 ft (highest road in Texas).
Old Nov 10, 2006 | 04:50 PM
burners's Avatar
burners
Cruise-In V Veteran
Mountains, haha. That's a good joke. It should be a great weekend for cruising, have fun. I had forgotten about the big airshow they have...maybe. Is the Petroleum Museum open on Sunday?
Old Nov 10, 2006 | 04:58 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Nov 10, 2006 | 05:00 PM
The Spark's Avatar
The Spark
Yep - 2 PM to 5PM
http://www.petroleummuseum.org/
Click on Chaparral Gallery for the cars. They have a pretty cool portion of a DVD available - good race footage from the 60s.
Old Nov 10, 2006 | 05:07 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
I didn't know it was powered by a ZL-1!!!
http://www.photoessayist.com/canam/c.../chaparral.htm
Old Nov 10, 2006 | 05:30 PM
burners's Avatar
burners
Cruise-In V Veteran
Yeah, those Can-Am cars are awesome! Good photo, Jughead. Doesn't it look like something from Star Wars? I don't want to do anything that obtuse but I think a compromise can be figured out.
Cool, open on Sunday. That could work out well.
To Aerodynamic suction device for a C3
Old Nov 10, 2006 | 05:37 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
You could be the first to do this!
http://www.airhogs.com/airhogsProduct.jsp?key=1477
Old Nov 10, 2006 | 05:51 PM
burners's Avatar
burners
Cruise-In V Veteran
That's cool! It could be very handy in rush hour traffic or if the elevator is full..."no problem, I'll take the Vette and meet you upstairs."
Old Nov 10, 2006 | 10:36 PM
RIJVETTES's Avatar
RIJVETTES
you guys will feel better tomarrow
