Scatter shield, which one?
Old Nov 12, 2006 | 11:47 AM
68RATVT's Avatar
68RATVT
Default Scatter shield, which one?
Anybody running a scatter shield or blow out wrap in a 68 manuel trans.
Which one and was there enough room or are there mods?
Old Nov 12, 2006 | 12:36 PM
Gordonm's Avatar
Gordonm
I have the Lakewood shield on mine. I did have to cut the bracket off the drivers side but other than that it fits fine.
Old Nov 12, 2006 | 12:46 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Mcleod bellhousings are made to tighter tolerances, less trans aligning problems
Old Nov 12, 2006 | 12:53 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Yellow hit the nail with a sledge on this one.
Old Nov 12, 2006 | 01:46 PM
68RATVT's Avatar
68RATVT
So they have more protection? Ok, I just looked it up, it's a blow proof housing, hhmm..
Old Nov 12, 2006 | 05:19 PM
Gordonm's Avatar
Gordonm
No more protection than a Lakewood just a little tighter tolerance. My Lakewood needed .007 offset dowel pins. Not a big deal at all. They are both blowshields and will do the same thing.
Old Nov 12, 2006 | 09:02 PM
68RATVT's Avatar
68RATVT
Thank you for the help, will be a winter upgrade....
Old Nov 12, 2006 | 09:03 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Get a Lakewood bellhousing! They are blowproof and won't need a scattershield..
Old Nov 12, 2006 | 09:06 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Nov 12, 2006 | 09:20 PM
SHAKERATTLEROLL
lol Do what where when ha?
Old Nov 12, 2006 | 10:39 PM
68 NJConv 454's Avatar
68 NJConv 454
How does a bellhousing protect the trans from blowing up? The bellhousing may protect the flywheel & clutch from scattering but not the trans. Right?
Old Nov 12, 2006 | 11:09 PM
68RATVT's Avatar
68RATVT
Right, I was curious as to what people had already installed for the clutch,flywheel safety. SINCE there is NO safety feature for a blowout.( sorry, I got reemed for talking badly about the aledged safety of a vette on another post).
Good info on what is possible, your questions makes me wonder if a tranny cover is needed, hhmm, probably not...
Old Nov 13, 2006 | 12:49 AM
Solid LT1's Avatar
Solid LT1
I run a "swap meet" Lakewood 2 piece. You need to look and cut the flange off the bottom of the scattershield if your car sits lower than stock or it will hang up on any speed bump you try to pass over. Don't worry about the loss in strength, the parts will exit out of the bottom towards the track and not cut your foot off. I run a scattershield because of my prefrence for the L-88 14lb nodular iron flywheel.
Old Nov 13, 2006 | 01:05 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Which ever you buy, make SURE to propelry align it or you could fight shifting problems..... .005 max runout.
To Scatter shield, which one?
