Starting tips?
Old Nov 12, 2006 | 05:04 PM
blackvettenut's Avatar
blackvettenut
7th Gear
Default Starting tips?
My 1968 wouldn't start so I used an electric jumper and she ran fine. I thought the battery was the problem so I replaced it and then tried to crank her over. Nothing.....
No sound, no clicking, nothing.
Alternator? Starter? any ideas or tips??????
I'd appreciate any expertise very much.
Jeff
Old Nov 12, 2006 | 05:14 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
You have a bad solinoid or a loose battery cable most likely.
A bad battery will at least TRY to start the car
Old Nov 12, 2006 | 05:29 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Check all your grounds and connections at the starter. You may have a dead spot on the starter as well. Good luck.
Old Nov 12, 2006 | 05:40 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Take a real good look at your battery cables and make sure you have a clean connection at the battery and that the cables themselves show no signs of corrosion. Do this and the other suggestions and if you still have a problem , do a search as there are several other posts on this subject for you to look at.
Old Nov 12, 2006 | 08:53 PM
blackvettenut
7th Gear
Default Will do
Thank you I will do allk of those efforts and reply. THANK YOU !
Old Nov 25, 2006 | 10:04 PM
blackvettenut
7th Gear
Default starting tips THANK YOU !!!
Thank you for the advice. It wound up being the ignition switch.
Thank you VERY much.
Blackvettenut
To Starting tips?
