gas tank removal
Old Nov 12, 2006 | 09:41 PM
speedreed8's Avatar
speedreed8
Default gas tank removal
how do you remove the fuel tank on a 79. i need to check my sending unit , i dont think its working correctly, is there a secret to getting the gas tank out of there from the bottom.??
Old Nov 12, 2006 | 10:05 PM
68 NJConv 454's Avatar
68 NJConv 454
i beleive the sending unit is on the bottom. My 68 was on the bottom, i think my 74 & 78 were also. No need to remove the gas tank, but you DO need to remove all the gas first.
The below is what I did on my 68 as it is still fresh in my mind, may be different for your year, but hopfully it helps a bit.
You have to start by unbolting the crossmemeber bracket that runs from side to side to the frame. (4 bolts) There should be two straps that run around the gas tank and hooks to this crossmember. you can remove the straps and unbolt this crossmemeber and drop the tank. Oh yeah, obviously the spare tire carrier has to be outa there. Not sure how the exhaust comes into play as I had already pulled mine out before I got to the gas tank. Try your best to access the sending unit without pulling all this stuff off. Although I would be curious to see if your tank sticker was still on there. Unfortunately mine wasn't.
Good luck.
Hopfully someone will chime in here with more info more specific to your vette year.
Old Nov 12, 2006 | 10:23 PM
MakoShark72's Avatar
MakoShark72
72 as well, I just replaced my tank and sender! Makes it easier to remove mufflers, but thats on a 72, thats all I know
Old Nov 12, 2006 | 11:41 PM
justaguy10825's Avatar
justaguy10825
1978...Sending unit on top... Gotta drop the tank..
Old Nov 12, 2006 | 11:48 PM
speedreed8's Avatar
speedreed8
thanks for the info guys, i want to drop it to take alook inside to see what surprises are in there and also see if the build sheet is on top.
Old Nov 13, 2006 | 12:04 AM
justaguy10825
The hardest part on the 78 was disconnecting & connecting the fuel lines on the top of the tank.. It was a real pain... Change all of the lines while your there...
John
Old Nov 13, 2006 | 05:33 AM
hunt4cleanair's Avatar
hunt4cleanair
John got it right. Sending unit can be removed through the top without dropping the tank but those rubber hoses are stiff. Cut them and replace with proper hose type. I had an article published in Corvette Enthusiast that describes the process along with testing the sending unit. That was an October 2006 Edition. If you can't get it, I can scan it and post.
To gas tank removal
