Sealing Windshield + Trim Pieces
Old Nov 13, 2006 | 01:09 PM
79vetter's Avatar
79vetter
Default Sealing Windshield + Trim Pieces
I had the local glass co. install a new one this weekend and stressed to them that I did not want gaps between the center trim and side w/s trim pillars. It looks like there will some anyways so I want to be able to still seal the top center windshield molding and the 2 on the sides from water.
Am I Ok to stuff some strip caulking in the gaps or undereath the moldings so that water can't get to the frame? Or what other options are there?
Old Nov 13, 2006 | 02:09 PM
myoriginal77's Avatar
myoriginal77
I wouldn't use strip caulk. I'd use some self leveling sealer or windshield sealer that you can get at a body shop supply place. 3M windo-weld I think.
Frank
Old Nov 13, 2006 | 04:16 PM
Ed Blue 03's Avatar
Ed Blue 03
If you're just using it to seal and not to bond the windshield to the frame you might be able to use RTV. But, you probably want to use urethane windshield sealer. Post a PIC.
Old Nov 13, 2006 | 09:33 PM
SIXFOOTER's Avatar
SIXFOOTER
Originally Posted by myoriginal77
I wouldn't use strip caulk. I'd use soem self leveling sealer or windshield sealer that you can get at a body shop supply place. 3M windo-weld I think.
Frank
Yep, thats the way to go. seal it real well all the way from the edge of the glass to the edge od the WS frame on the top and sides. Make sure the WS frame is well painted with some type or rust encapsulator. you want to make sure there is nowhere for water to sit or get trapped under anything.
Old Nov 14, 2006 | 03:46 PM
1tuffref's Avatar
1tuffref
I filled it all the gaps between the windshield and the frame with roofing cement using a chalulking gun. I really don't think you can seal the molding to the windshield though. The top molding just clips in and the side moldings are held on with just a few sheet metal screws. No much chance of keeping it all from moving.
Old Nov 14, 2006 | 03:51 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, the trim should be installed without sealer.
To Sealing Windshield + Trim Pieces
