LS1 guys, fuel tank question
Old Nov 13, 2006 | 03:26 PM
corvette74's Avatar
corvette74
Default LS1 guys, fuel tank question
Looking at putting a LS1 in did you guys modify the original fuel tank or can you get a new one that will use an internal pump? If a new tank where did you get it from?
All opinions and pictures welcomed
Old Nov 13, 2006 | 04:43 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
82 sending unit with a 95 LT1 Vette pump. Now that I know what I'm doing, I would just modify the stock sending unit with a late model LT1 pump and save the cash I spent on the sending unit.
You will also need the pump harness. You can get the pigtail from GM.
Old Nov 13, 2006 | 04:49 PM
70 LS1's Avatar
70 LS1
You can get a new tank from rock valley.
I used the stock 1970 tank with an external inline pump.
Old Nov 13, 2006 | 05:29 PM
bruced267's Avatar
bruced267
I dont think an 82 sending unit will fit a 74? Im sure others will chime in though. On my 81 I did use the 82 sending unit, Ive been told that in tank is better, but I have also read that other fourm members have had good luck with external pumps!! Good luck with your build!!
Old Nov 13, 2006 | 05:36 PM
Scooter70's Avatar
Scooter70
I copied everything that Jeff did. Stock tank with Walbro external pump pushing through a '99+ Corvette filter/regulator.
Old Nov 13, 2006 | 09:10 PM
73ls1's Avatar
73ls1
I sent my 73 tank to Rock Valley auto parts in Stillman Valley, Il.They cut the tank ,put in a sump and a fuel pump in it. I have used this set up for 5 yrs. with my tune port and now my ls1,works great! Had a external pump before this ,it was noisey and had a vapor lock problem. The phone#is 815-645-2271.Good luck with your conversion,I love driving my 73 now.
Old Nov 14, 2006 | 10:41 PM
corvette74's Avatar
corvette74
Thanks for the info guys.
Old Nov 15, 2006 | 12:44 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
I'm going to use an internal fuel pump from Tanks Inc. with my stock tank. I will need to modify my tank. The good thing is you can modify the pump height. I don't want to risk an external pump being to noisy or even heard. As for the sending unit right now I'm using stock, since it works with my stock gauge. However, I'm in the process of researching new gauges.
Here's a link of the pump:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
Old Nov 15, 2006 | 08:02 AM
PatsLs1vette's Avatar
PatsLs1vette
i used my 73 tank and modified a 89 truck sending unit and used a walbro 255 pump on it and mounted it into the top my tank<BUT i ran the pump dry and burnt it up,so im building a new tank over th winter with baffles.
Old Nov 15, 2006 | 08:18 AM
mrvette's Avatar
mrvette
Scooter, I have an external pump on my TPI setup....but about that regulator,...what advantage does it have?? do I still need the return line?? does it use a vacuum line??
Old Nov 15, 2006 | 10:39 AM
corvette74's Avatar
corvette74
Thanks Gr8Wht they even have a Canadian dist. not to far from where I am.
Dale
Old Nov 15, 2006 | 10:50 AM
70 LS1's Avatar
70 LS1
The regulator does not use vacuum and is a constant pressure regulator set at 58psi. It uses a return line and the advantage is it can be mounted near the tank with a short return line and a single line running to the fuel rail.
Old Nov 15, 2006 | 11:22 AM
PatsLs1vette
I used the same filter/regulator,saves time plumbing 2 lines up front return line is alot shorter ,its alittle bit more money for the filter,but it works better.I got mine through napa alot cheaper then gm's price.
Like this
http://www.westcoastcorvette.com/pc-...el-filter.aspx
Old Nov 15, 2006 | 10:30 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
Corvette74 - I will be modifying my tank similar to this...
http://www.ls1tech.com/forums/showpo...6&postcount=14
Old Nov 15, 2006 | 10:39 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
I forgot the 74 still feeds from the bottom. Looks like a frame mounted pump will work in your situation.
Old Nov 19, 2006 | 11:14 PM
martinsw's Avatar
martinsw
Interesting concept - save $$ ( these C3's usually suck the $$ up). Can you tell more of using late model LT1 pump and pump harness w/stock sender (seems like wouldn't be sufficent wires going into tank w/stock sender?)? I will use the C5 filter/regulator in my 79 conversion, have been on the fence re walbro in tank, or external - like the idea of in tank, but hate spending more on the '82 sender.....
Old Nov 20, 2006 | 09:13 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
I'll compare both sending units and see what the difference is. The 78 has to have at least one wire for the gauge, so not sure why you couldn't put two or three.
The C-5 filter/reg is the way to go.
The only issue I have with the intank pump is when the fuel level is below 1/8 a tank, it will run dry in hard G turns. I guess foam would solve that.
To LS1 guys, fuel tank question
Old Nov 20, 2006 | 10:04 AM
PatsLs1vette
I just switched to an inline holley pump this weekend for mine that i had laying around for my nitrous system from the tpi,havent test drove it yet but at least it started up.
Old Nov 20, 2006 | 12:18 PM
carriljc's Avatar
carriljc
Default I adapted an in-tank Bronco pump
from a 1990 Bronco. There are some pictures in my corvette pictures off to the left here.
The Bronco fuel pump comes in a cannister assembly and the fuel returns to this cannister. I can change the pump from the top and I was able to keep my original fuel tank sender. The design allows the fuel pressure regulator return flow to go back to the pump suction. This means that your pump will not lose suction and lets me use my tank without baffling.
There are now many different cannister-type pumps which would allow you to do this. That plate that sits on top of our tanks gives us many options.
Old Nov 20, 2006 | 06:39 PM
SuprJames's Avatar
SuprJames
I used a Rock Valley stainless tank. Comes with baffles and you can pick the in-tank pump. Fits just like a stock tank. Using the 99+ C5 filter so I only have to run a return line from the filter to the tank instead of all the way to the fuel rail. Expensive, but at least I know it's done right. Not convinced on the running without baffles.
