Shifts into reverse with a bang!!!
Old Nov 13, 2006 | 05:27 PM
the-esses's Avatar
the-esses
Default Shifts into reverse with a bang!!!
Hi guys,
I have a 75 auto that every time I shift into reverse it goes in with quite a bang, it engages (apart from the noise) and drives okay!
Is this a Trans problem or a propshaft/Diff problem?
Many thanks in advance.
Old Nov 13, 2006 | 05:31 PM
sly vette's Avatar
sly vette
U-Joints
Old Nov 13, 2006 | 06:04 PM
SILVERSIXX's Avatar
SILVERSIXX
Differential mount.
Old Nov 14, 2006 | 09:41 AM
Hvymtlc5's Avatar
Hvymtlc5
Check both.
Old Nov 14, 2006 | 10:01 AM
Durango_Boy's Avatar
Durango_Boy
Check:
Transmission Mount
Diff Mount
U-Joints
It could be any of those three things.
Old Nov 14, 2006 | 10:34 AM
Jims79's Avatar
Jims79
Originally Posted by Hvymtlc5
Check both.
don't think it the trany mount but its a cheap & easy fit. the diff mount is also cheap & easy. G/L
Old Nov 14, 2006 | 11:10 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Could actually be a combination of all three. I've got the first two done and I still get a solid, though reduced clunk. I also get a rattling like noise on cruising or decelerating. Presumably this is the u-joints.
Old Nov 14, 2006 | 03:09 PM
Durango_Boy
It's odd. I have bad u-joints and don't get any thump at all.
Old Nov 14, 2006 | 03:13 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Out of curiosity, is this a new problem or has it been there for sometime? My experience with a few a C3's is that they can be fairly rough when going into reverse. If you are getting a clanking sound, though, it would point to one of the suggestions above. Just my 2 cents.
Old Nov 14, 2006 | 07:06 PM
Durango_Boy
Most all C3 Vettes will squat when put in drive, and sit back up when in reverse...it's just normal of their behavior. When you hear it as well as feel the movement then you have to start checking. If it's a warning sign of u-joints...and you ignore it...you could end up in trouble.
Old Nov 15, 2006 | 02:33 PM
the-esses's Avatar
the-esses
Thanks for the replies, Guys.
I'll try and give it a through check over as it's off road for the winter, and try and do all of the above, I know the Diff seal needs to be done as well, is there anything else that could do with renewing while I'm at it, gearbox seal? Nice to have all the parts to hand especially being in the UK!!
Old Nov 15, 2006 | 04:21 PM
Solid LT1's Avatar
Solid LT1
Use a Urethane fron Differential mount and the oil/lube won't deteriorate it. I think front diff mount is your problem.
Old Nov 15, 2006 | 05:02 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Just a thought; How high is your idle? When your idle is a little too high it will make the shift to Reverse or Drive a little rough. If it's where it's supposed to be the other posters are on the right track.
Old Nov 15, 2006 | 06:15 PM
Durango_Boy
That's a good call. With an idle close to 1000 or better you'll have a lot of 'Oomph' getting through the drive train.
Old Nov 15, 2006 | 08:19 PM
whoodiestyle's Avatar
whoodiestyle
im in the same boat as you mine like drops and bangs the whole car when shifting from R N 3 2 1 all of em it fells like the car drops down when i shift it to 3rd is it something i should worry about?
Old Nov 15, 2006 | 08:30 PM
Durango_Boy
If it 'CLANKS' then yes...if not...don't worry, and check your idle.
Old Nov 16, 2006 | 09:23 AM
Corvetteran's Avatar
Corvetteran
Just to add to the general comments...I completed a partial overhaul of my 70, to include rebuilt engine, rebuilt TH400, new U-Joints, new bushings throughout the drive train, and I still get the same clunk I used to get prior to the rebuild. I must say though that my idle is set higher, and that I did not have the rear rebuilt.
I will reduce the idle speed since I believe that it will make a big difference.
Old Nov 16, 2006 | 10:35 AM
Durango_Boy
What is your idle speed right now? Is there a specific reason why it's high like that or it's just a case where you haven't lowered it in a while?
To Shifts into reverse with a bang!!!
