Can some make a suggestion as what cam to use in my sb? Please excuse my ignorance,I just don't quite understand the choices. The car will be driven on the street, not raced (much) I'm trying to build a nice driver w/ a little more to it. The rear is a stock 3:36, crank is shaved .30? My son telling me to build a 9.5 compression? Block has been bored .30 using flat headed pistons. Also, the car has an auto trans that I'm returning to it's original 4 speed. Heads and block will be shaved, along with a head job. Also, my kid is telling me to go with a new aluminum intake and change the exhaust to headers in stead of the stock manifolds. Any help is appreciated WB
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by War Bonnet
The rear is a stock 3:36, crank is shaved .30? My son telling me to build a 9.5 compression? Block has been bored .30 using flat headed pistons. Heads and block will be shaved, along with a head job. Also, my kid is telling me to go with a new aluminum intake and change the exhaust to headers in stead of the stock manifolds. Any help is appreciated WB
headers are a good thing and the aluminum intake will save weight but the vette intakes are pretty good......you have lots of cam choices from the mild to the wild...remember you need new lifters when you get the cam and mabye even new springs....so do your home work and if they offer a kit it may be the least expensive way to go.....its really easy to wipe a cam on startup so you really need to have the car be able to fire right up and run for the first 20 minutes....i have a Comp Cams XE268 and i like it.....but you have so many choices...and it sounds like you have a machine shop doing your work so why not ask them....also you can buy books of SBC buildups and see what they did and what the dyno results were.....good luck.....don't rule out the GMPP hot cam
Thanks bobs77vet, Funny the only original piece on it is the intake! Yep on the lifters and springs. Your right again, it's in a shop, he gave the number at comp cams, give them my requirements and they will make their reco. I'm trying to do my homework with the experts here first WB
You might consider looking at Summit's 1103K, their kits are great deals. It is ground on 112 centers to reduce the overlap and would work well for a daily driver with 9.5:1. Make sure you know Exactly what your static compression is so you can compute your DCR Dynamic compression by using the inlet valve closing point.
Way over my head, I'm lost or just plain stupid! How would I figure these calculations? Probably do better talking to my son Thank you Scott! I will look at Summit's products. WB
not for nothing.....but if the shop is going to warranty the work let them have the last word on cam selection......no need to get into a pissing contest if you get a wiped lobe and have them say well its what you wanted......
WB,
Here is a link to a calculator so you can understand what is happening with your engine. Comp cams grinds just about everything on 110 LSAs which tends to kill your bottom end torque. I'd suggest asking them about grinding whatever you want on at least 112 centers to reduce overlap and increase your bottom end power.
WB,
WB, also don't discount the stock GM cams for a car with a stock automatic with 3.36 gears. The base cam retarded 4 degrees works very well with a 9.5-9.75 SCR engine. The L-79 and L-82 cams like 10-10.25:1 SCR much better. Many folks don't like them because they don't sound bad a** enough but they do work well and are dead reliable and are cheap. Here are some numbers to chew on:
Here are very accurate numbers from Engine Analyzer for a .030" over 350, 9.75:1 SCR, an OE manifold with a 750 CFM carb, stock 2" manifolds and 2.5" exhaust pipes. Equiped with full front end accessories - SAE net, peak torque, 80 percent bandwidth, peak power.
Why don't you go to the bookstore and pick up a few books about building street engines? Take some time to read and learn and you will come to better understand how it all works together. Then you can ask better questions and make better decisions about your motor.
I'm not trying to flame you at all, just help you to not regret something in the future. It's not rocket science, and even basic knowledge will serve you better than blindly accepting others opinions without understanding why.
thats an excellent cam xe262h....its one step below my cam although pulls the same HP and torque numbers.....if this fits all your other needs it is a good cam....
