Where does the upper rad hose go?
Nov 13, 2006 | 07:50 PM
Okay, here's the scoop.
1973 SBC 400 bored +.020 to 405 (Complete roller retrofit.)
1989 SBC heads - 14102193
1994 Impala LT1 intake manifold
Where, since there is no t-stat housing...does the upper rad hose connect?
Thanks.
Nov 13, 2006 | 08:28 PM
Cruise-In III Veteran
St. Jude Donor '05
Interesting combo
Nov 13, 2006 | 08:37 PM
I believe this is what you want to read...
if you read the website, I believe he later started doing the water outlet at the aft end so as to not interfere with the forward-end stuff.
Take a look and see if it helps.
http://www.lt1intake.com/files/Coolant_mods.htm
Nov 13, 2006 | 08:38 PM
here's the rear exit picture...
Nov 13, 2006 | 08:39 PM
Quote:
Originally Posted by carriljc
So I have to buy a remote t-stat housing? This guy won't return emails about the manifold...so is he who I have to rely on for the housing too?
Nov 13, 2006 | 08:48 PM
Nov 13, 2006 | 08:49 PM
Nov 13, 2006 | 08:50 PM
St. Jude Donor '07
The remote t-stat housing is a Weiand unit for use with superchargers. It's available from Summit, Jegs and eBay.
Nov 13, 2006 | 09:04 PM
Quote:
Wow they're pricey, I have one bookmarked but I didn't think they'd cost $80.
Nov 13, 2006 | 09:48 PM
Offy part is only ~55 Bucks
Nov 13, 2006 | 09:58 PM
Excellent...I missed that one...and since I don't use the bypass it'd work better. Thanks.
Nov 13, 2006 | 10:34 PM
St. Jude Donor '07
Quote:
If you're patient, used Weiands come up on eBay in the $35-$60 range relatively often. I found mine for $35 after shipping.
Nov 14, 2006 | 09:27 AM
My next stop is the for sale section. I'll search it, and then post a WTB for one.
Now that I know what to get, where will I want to mount it? Can I fab a bracket, and mount it right on front of the engine similar to where it already was...just on a bracket in front of the motor?
Nov 14, 2006 | 11:23 AM
St. Jude Donor '07
I think it's just one of those "mount it where you can get it to fit" things. The LT1 intake page might have some photos with good ideas.
Nov 14, 2006 | 03:10 PM
I want to try to mount mine in the front between the accessories...on a custom bracket of some kind.
