Calling all Holley & NCRS Experts
Subscribe
Nov 13, 2006 | 07:56 PM
Would you please help decipher the numbers on the Holley dual-line (not double pumper) carb on my 72 LT-1? It appears to be era correct. I want to know whether or not it could be original and don't have a book on these. Any help would be greatly appreciated.
Stamped on the front of the primary butterfly housing:
3999263 GA
LIST 6239-1
0787
Reply 0
Nov 13, 2006 | 08:19 PM
6239-1A 72 Holley 4-brl 350 Camaro Z-28 & LT-1 Manual trans
Does yours have an A after the last number?
Reply 0
Nov 13, 2006 | 08:21 PM
PS...
Im not an expert in NCRS unless its the backwards way and I dont know much about Holly's.
Reply 0
Nov 13, 2006 | 08:58 PM
There was no A following the 1, but I'll check again just to be sure. TTT.
Reply 0
Nov 13, 2006 | 09:23 PM
FWIW, I have what I believe to be an original carb off a '72 LT-1 (at least that's what the guy that sold it to me told me) and it doesn't have an A at the end either.
Reply 0
Nov 13, 2006 | 09:47 PM
Quote: Would you please help decipher the numbers on the Holley dual-line (not double pumper) carb on my 72 LT-1? It appears to be era correct. I want to know whether or not it could be original and don't have a book on these. Any help would be greatly appreciated.
3999263 GA
LIST 6239-1
0787
My 72 LT-1 has
3999263
LIST 6239-1
2542
254th day of 72
Reply 0
Nov 13, 2006 | 10:11 PM
3999263 GA
LIST 6239-1
0787
Looks like it's........
dated
0=1970
7=month
87= week made
3999263= Chev # the GA are modification codes
Holley # List 6239-1
Hope this helps
Reply 0
Nov 13, 2006 | 10:15 PM
Quote: My 72 LT-1 has
3999263
LIST 6239-1
2542
254th day of 72
I think yours is
2=1972
5= month
42= week
3999263 again the Chev# with no mods
Holley number =List 6239
Looking at the NCRS judging Manual
I think this right, if not maybe someone can correct me? WB
Reply 0
Explore
Nov 13, 2006 | 10:23 PM
Quote: I think yours is
2=1972
5= month
42= week
War Bonnet, I thought I read somewhere that sometime in late 72 Holley went from 3 digit date code to 4 digit. 3 digit was as you discribe. 4 digit went to Julian date code. Julian day 1 thru 365 with last digit being the year. I am going by memory though so you now the old saying. Memory is the secound thing to go......can't remember the first.
Bullshark
Reply 0
Nov 13, 2006 | 10:30 PM
Quote: War Bonnet, I thought I read somewhere that sometime in late 72 Holley went from 3 digit date code to 4 digit. 3 digit was as you discribe. 4 digit went to Julian date code. Julian day 1 thru 365 with last digit being the year. I am going by memory though so you now the old saying. Memory is the secound thing to go......can't remember the first.
Bullshark
The Mrs. can tell you what went first
About the codes I don't see any changes listed for later produced 72's, but the manuals have been wrong before. Do you know when you car was built, and does it match up to the week or close to it? WB
Reply 0
Nov 13, 2006 | 10:32 PM
Quote: Looks like it's........
dated
0=1970
7=month
87= week made
Hope this helps
Were there that many weeks in 1970?
Reply 0
Nov 13, 2006 | 10:38 PM
Quote: Were there that many weeks in 1970?
I believe it's from the begining of the production year? (Sept)
I'm tranfering info from the 70-72 Judging Manual ??? Would be nice to know the cars vin# see if it's a later prod.WB
Reply 0
Nov 13, 2006 | 10:48 PM
If you want my VIN, it ends in 13949. Believe the trim tag decodes to assembly beginning in Feb 72, but need to verify.
Reply 0
Nov 13, 2006 | 11:04 PM
Quote: If you want my VIN, it ends in 13949. Believe the trim tag decodes to assembly beginning in Feb 72, but need to verify.
I read the manual again, your # say's it's a 1970 Holley
Maybe Bullshark can verify his vin against the week. When reading the dates on a Rochester it's the first three digits are the day the fourth is the year. WB
Reply 0
Nov 13, 2006 | 11:13 PM
WB, I can't verify VIN right now, the car is offsite in storage. But, It is a late year build because it has A/C
Bullshark
Reply 0
Nov 13, 2006 | 11:26 PM
Thanks WB. Do the four-digit numbers on the metering blocks denote dates as well, or something else? Also, do you know of any Holley docs to decode the GA mod codes? I'm good with online searches but would prefer to start narrower.
Interesting that both of these 1972 Holley 6239 carbs on E-Bay also have the GA codes (same seller):
1. http://cgi.ebay.com/ebaymotors/1972-...spagenameZWD1V
2. http://cgi.ebay.com/ebaymotors/1972-...ayphotohosting
He claims the three digit date codes represent (in order) the last digit of the year, the month, and the week of that month. 181 = 1971, 8th month, 1st week.
Reply 0
Nov 13, 2006 | 11:51 PM
WB, now I am really confused. I checked my 70 LT-1 and it has a List 4555 with a date code of 9A2 which is 1969 Nov - 2nd week. The cars build date was jan 22 1970. Other List 4555 carbs on ebay have:
044 = 1970 april 4th week in that month
022 = 1970 Feb 2nd week of that month
051 = 1970 May 1st week of that month
Month designators go 1-0 - Jan thru Oct. A=Nov and B=Dec
Three digit date codes only have 1 to 5 weeks in a month nothing bigger.
I thought four digit date codes went like
First three digits = Julian day 1- 365 (366 leap year) and last digit =year 2-72, 3-73 or 83 etc. etc.
Hope someone can shed some light on this subject??????
Bullshark
Reply 0
Nov 13, 2006 | 11:59 PM
http://www.chevellestuff.com/generic/holley_carbs.htm
I found this site and it lists a different way they date the carbs and its broken down by "Pre 72" and "Post 71". This site says Corvettes are not included but maybe it will help.
I cant find anything on Corvette specific date codes though other than what I first posted. Sorry
Reply 0
Nov 14, 2006 | 08:00 AM
Quote: Thanks WB. Do the four-digit numbers on the metering blocks denote dates as well, or something else? Also, do you know of any Holley docs to decode the GA mod codes? I'm good with online searches but would prefer to start narrower.
No thats a part number only. Not sure what the modification to the carb relate to the codes, I'll check the manual tonight. WB
Reply 0
Nov 14, 2006 | 08:08 AM
Quote: WB, now I am really confused. I checked my 70 LT-1 and it has a List 4555 with a date code of 9A2 which is 1969 Nov - 2nd week. The cars build date was jan 22 1970. Other List 4555 carbs on ebay have:
Bullshark
You must be correct, but there is nothing in my manual on four digit codes on Holley's??? Can someone else jump in here? TIA WB
Reply 0
