fuel vapor cannister problem
Old Nov 13, 2006 | 08:33 PM
Thinpockets's Avatar
Thinpockets
Default fuel vapor cannister problem
I had some fuel odor problems in the garage and of course in the house and was ordered by the higher authority to fix it. I discovered that both vacuum lines from the cannister to the carburetor were GONE. Another surprise.
I went to NAPA and bought the appropriate size vacuum line and a tee for the PCV valve and hooked it up like the Assembly Manual showed. Looked real good. Problem is when I took it for a test drive a couple of days later it ran really rich and smoked for about the first mile or so. The second test ride a couple of days later - same thing. After driving a couple of miles it runs great. I have pulled both vacuum lines from the cannister and neither smell of gas.
Is it even possible for fuel to leak into the cannister while sitting in the garage and then get sucked out into the carb in the first 3 or 4 minutes of running and then refill the next time it sits for a day or so?
Any other ideas?
Old Nov 13, 2006 | 09:08 PM
shafrs3's Avatar
shafrs3
If the vapor separator at the fuel tank is defective, it can allow raw fuel to travel to the vapor canister. I've had this experience, fuel leaked from the bottom of the canister.
The separator is located on the top of the tank driver's side .
Old Nov 14, 2006 | 07:22 PM
Thinpockets
I disconnected the lines from the vapor canister to the carb, plugged both the lines and the carb ports and the car runs great. Hook them up again and it runs like . . . well real bad.
Does anyone have or know where I can find any diagrams of how the vapor system actually functions?
shafrs3 - you're probably right about the fuel separator but what I can't figure out is how the fuel gets to the carb.
Old Nov 14, 2006 | 07:59 PM
shafrs3's Avatar
shafrs3
Going from memory, the purpose of the system is to trap fuel tank vapors and route them to the engine when it is running and store them when it's not, an early emission control system.
The fuel separator is similar to a carburetor float bowl with a float and needle inside. It works by capturing and returning fuel to the tank by closing the needle valve to the vapor vent line and draining fuel back to the tank.
The canister is a storage place for the vapors when the engine is off. There is a vacuum operated valve on top that allows vapors to be ingested into the engine when it's running and closed for storage when it's not. When you first start the engine the valve opens and the accumulated vapors are drawn into the air cleaner.
Old Nov 14, 2006 | 08:14 PM
randyredleg's Avatar
randyredleg
I see Auto Zone take a beating on this forum, but they have a good web site with lots of repair info and pictures.Go to Auto Zone.com, and input your model year. Then, on the right of the page, click Vehicle Repair Guide. Select Emission Control and Fuel System, then Emission Controls. Finally select Evaporative Emission Controls.
Old Nov 14, 2006 | 09:25 PM
Thinpockets
Very good information site. Thanks.
It and some other articles have me convinced to replace the canister and filter to store the vapor and not release it all at once. Also I will replace the vapor separator on the tank so there will be less fuel in the canister to convert to vapor.
Thanks to all you guys for the into.
Old Nov 14, 2006 | 10:20 PM
shafrs3's Avatar
shafrs3
If the separator is working properly no fuel will be in the canister, only vapors.
Old Nov 14, 2006 | 10:22 PM
Thinpockets
Seems like that shoud be the starting point.
Old Nov 15, 2006 | 08:48 AM
SharkAttack's Avatar
SharkAttack
Good info to know, thanks. I recently hooked up my canister by purchasing vac hoses to go from the canister to the carb (was not hooked up when I bought the car). Engine runs a little rough now, so I suspect a small vac leak on the original (34 year old) rubber hoses from the tank to the separator, separator to metal line, etc. Going buy more hose now...
Old Nov 15, 2006 | 09:27 AM
rastadr's Avatar
rastadr
i dont really understand why any of us run this thing anyway. why not just gut it and block it off? once any high performance mods are done cam intake headers etc why run any extra vacuume lines in the first place. the gas cap is vented and any fumes from unburnt gas in the carb will be gone in a few minutes. the truth is that i just broke the little vaccume attachment that sits on the side of the fender and i want to gut it all and put a cooler for the power steering/hydroboost where the cannister is, so air goes through it on its way out the side gill.
Old Nov 15, 2006 | 09:44 AM
shafrs3's Avatar
shafrs3
Some folks try to keep the emission controls working, this system causes no penalty in power output.
Old Nov 15, 2006 | 01:07 PM
SharkAttack
I hooked up mine because my LT-1 is mostly original/stock and I sometimes smelled gas after driving it. If it were a modified car, this system would have been removed and placed in a box that sits in my garage. Nuff said?
Old Nov 15, 2006 | 06:58 PM
NHvette's Avatar
NHvette
Very few gas caps are vented ... only 68-74, and most of those are
EEC systems with sealed cap. I plugged my vapor line at the tank and use a vented cap, now.
To fuel vapor cannister problem
