Battery Drain?
Old Nov 13, 2006 | 10:17 PM
SoCalErv's Avatar
SoCalErv
Army
Default Battery Drain?
My battery has failed me twice now as I purchased the car two weeks ago.
Therefore, I set my DVM amp reading to 10 and connected the meter to the positive post to the disconnected positive battery cable and received a reading of .01 - .02. So far so good.
Then reconnected battery and put a test light between ther negative post and neagtice cable, no light, alternator is not drawing so far so good.
Here is my dumb question. In scenario 1 as I open the door the courtesy lights do not come on, should they? If I reconnect the positive then the courtesy light come on as the door is open.
The batter reads 12.4 volts with the engine off and 13.5 with the engine running. Is my battery suspect?
Old Nov 13, 2006 | 10:54 PM
SIXFOOTER's Avatar
SIXFOOTER
The lights should come on when you open the door. Do the lights turn off a bit after the door closes? Rerun the test 1, connect up the test rig, roll the window down, close the door. Watch the meter and see what happens, then open the door and see what happens. When you close the door, the lights should go out and the meter should drop down to <20ma.
Old Nov 13, 2006 | 10:55 PM
...Roger...'s Avatar
...Roger...
No I dont think your interior light would come on, should have just made the meter read higher.The 13.5 volts is about 1 volt low but shouldnt cause battery to go down.If your not in a hurry charge your battery and disconnect it- check voltage and leave it sit a couple of days and check again.If it goes down not connected then its bad.Make sure alt. belt is tight and connections are good.
Old Nov 14, 2006 | 09:44 AM
Lorin D's Avatar
Lorin D
I replace the starter on my '71 . A friend of mine reconnected the wires,
he had connected the ground wire to a wrong post. The battery would only stay charge for a day or so - tracking the probem we found that
he had connected the ground back to the starter . I wish you luck in
finding the problem .
Old Nov 14, 2006 | 09:46 AM
SoCalErv's Avatar
SoCalErv
Army
With test #1, cable off of positive post and DVM set to amps between the post and off cable the door lights will not come on if door is open. Should the DVM complete the circuit and allow the lights to come on?
I have a guru coming to check the DVM today.
Old Nov 14, 2006 | 11:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SoCalErv
My battery has failed me twice now as I purchased the car two weeks ago....
Define "failed." Bad or just low charge and the car wouldn't start?
13.5 at the battery with the engine running indicates the alternator is cranking as it should.
How old is the battery?
Old Nov 14, 2006 | 03:56 PM
SoCalErv's Avatar
SoCalErv
Army
The car would not turn over, just that nagging click sound. As for the age of the battery I do not have a clue as I purchased the car approximately two weeks ago.
I checked the fuses in my DVM and they were toast, shouldn't lend your tools. New fuses installed will retest tonight
Old Nov 14, 2006 | 04:09 PM
...Roger...
I think when you put a load like the courtesy lights on your meter its going to blow the fuse.If you want to check for draw just use a test light.
Old Nov 14, 2006 | 05:18 PM
Billysvette's Avatar
Billysvette
Here is a great piece of advise,put in a power switch (battery disconnect),inline between your battery and positive cable.alot of older vettes have problems with battery drain,sometimes its very hard to find the problem,and i think all vettes should have these switches especially when they sit along time during winter storage.It also helps with car theft.I put one in my car and love it,should have done it a long time ago.This will solve your problem but not the reason for your battery drain.Plus it will make your battery last alot longer,it did mine im going on 10 years,but im going to buy another (optima) no fluid (acid) in it.
Old Nov 14, 2006 | 06:22 PM
1stC3Vette's Avatar
1stC3Vette
I did a similar test on my brothers '76 to see what was draining his battery. I placed my DVM between the negative post and the negative cable. The interior lights worked and the DVM did complete the circuit. My meter is rated at 10amp max. If you exceed 10amps, you will blow the fuses like you have found.
You do not list what year vette you have. I found that my brothers problem was in the interior lighting circuit drawing .1amps and could not trace it down. I would recommend a battery disconnect for use at this point.
Good luck,
Dino
Old Nov 14, 2006 | 07:59 PM
Johnny_Johnson's Avatar
Johnny_Johnson
Good luck,
Dino
I had a similar problem with my '73. As it turned out the switch for the light in the storage compartment behind the seats was not adjusted properly and the light was on all the time even though the door was closed.
Later,
Johnny
Old Nov 15, 2006 | 09:36 AM
SoCalErv's Avatar
SoCalErv
Army
After replacing fuses the DVM worked fine. Scenario#1 - .005 amps everything off, my clock does not work. With door open the courtesy lights come on with replaced fuses and draws 1.630. Battery volts engine off 12.34, engine running 14.40. Conclusion must of left the center compartment door open once and drained the system. I have a 1969 coupe. Thanks
Old Nov 15, 2006 | 10:22 AM
...Roger...
You say your clock doesnt work? Go back to your test with your DVM and while drawing .005 -fiddle with the clock adjusting stem-see if you can get the clock to try and rewind-maybe bump the cluster to shock it-if it does and sticks-it can draw at least 10 amps-that might be your intermitant short or draw.Or just disconnect the clock.In older vettes I have heard the clock is not fused and if they stick they have caught fire !!!!!!!!!!! Clock guy told me that.
Old Nov 21, 2006 | 09:25 AM
SoCalErv's Avatar
SoCalErv
Army
Looking for validation that a draw of .005 amps is ok with everything off. It is my understanding if I reach .010 or greater I have a drain problem?
Old Nov 21, 2006 | 10:11 AM
Wuttin's Avatar
Wuttin
Later,
Johnny
I had the exact same problem but it was the light in the glove box of my 79. Ultimatley found it but not before getting a quick disconnect just to keep me up and running.
Best of luck
Old Nov 21, 2006 | 10:23 AM
The Spark's Avatar
The Spark
I have had problems with my 72 draining the battery after a few days. Thanks for reminding me of the clock. I forget that is how those clocks worked (been digital too long). My clock works intermittently. I plan to pull it one day and get it rebuilt.
I put a battery tender on mine. I have a secret audio radio on my Vette and don't want to lose the presets by disconnecting the battery (though I do like the anti-theft aspect of the battery disconnects).
Old Nov 21, 2006 | 10:43 AM
...Roger...
Erv I use a 12 volt test light for this test.A 12 v test will allow the clock to wind and not light up.I went out and tried to test the draw on my 12v test light.This is where my old brain starts to fog up.I set my meter on dc amps milliamp and on 2000--it read 1.5. My meter doesnt have a dc amp setting or at least I dont think it does.Hopefully some of the guys that understand a DVM will chime in.This digital stuff just throws me for a loop. For resistance I have a board with different resistors "labeled" so I can use them for comparison.
Just for fun I will go see if my old style meter will tell me how much my test light draws,its easier to use.
Edit-Sorry Erv the old meter just buried the needle-but I looked at the bulb in the test light and it says 24v C5W...So I'm guessing thats 5 watts
To Battery Drain?
