Spark plugs...
Old Nov 13, 2006 | 11:40 PM
jerrylee's Avatar
jerrylee
Default Spark plugs...
What is the proper procedure 4 tightening spark plugs.....And is Bosch a good brand...Thanx....Jerrylee///
Old Nov 14, 2006 | 01:17 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Plugs should be tightened according to torque specs. I've never had a problem running any plug that is designed for the engine it is used in. I've always heard people say this or that plug is no good, but never believed it. Practically all major plug manufacturers, including Bosch, have been in business for around 100 years and common sense would dictate that they know what they are doing, IMO, or they would not be around. The only exception to this would probably be the Split Fire plugs of a few years ago. (I'm sure these comments are going to open Pandora's Box, but again, these are just my opinions).
Old Nov 14, 2006 | 01:21 AM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by Jud Chapin
Plugs should be tightened according to torque specs. I've never had a problem running any plug that is designed for the engine it is used in. I've always heard people say this or that plug is no good, but never believe it. Practically all major plug manufacturers, including Bosch, have been in business for around 100 years and common sense would dictate that they know what they are doing, IMO, or they would not be around. The only exception to this would probably be the Spit Fire plugs of a few years ago. (I'm sure these comments are going to open Pandora's Box, but again, these are just my opinions).
BTW, I always use anti-seize on plug threads. This is particularly important with aluminum heads.
Old Nov 14, 2006 | 01:46 AM
EVIL_GRIM's Avatar
EVIL_GRIM
i like Autolite on chevy's, but use Bosch in my old Vw. was thinking about trying NGK in the vette to see if i get better gas mileage
Old Nov 14, 2006 | 02:56 AM
Kalway's Avatar
Kalway
I've personally had good results with autolites, also. Accel plugs work well, too, though. If you have standard SBC heads and headers, the accel shorties fit the best. I've found that with vortec heads, because of the plug placement and angles, standard length plugs don't seem to have any problems with touching headers.
Old Nov 14, 2006 | 04:32 AM
greyghost79's Avatar
greyghost79
also, i like and use Bosch plugs.
Old Nov 14, 2006 | 06:01 AM
jerrylee's Avatar
jerrylee
Default Plugs...
Thanx 4 your replys.......
Old Nov 14, 2006 | 06:05 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Hey Jerry, I thought about using anti seiz on my sparkplugs too, but if you change them yearly, then it shouldn't be necessary
Old Nov 14, 2006 | 09:26 AM
68RATVT's Avatar
68RATVT
If you are running a Big motor, don't use platinum plugs, they will foul faster due to the rich mix. Platinums are a harder surface and do not clean off carbon. In a later motor they work fine, IMO the NGK v-groove are the best....
Old Nov 14, 2006 | 01:11 PM
Scott Marzahl's Avatar
Scott Marzahl
I vote for Autolite copper core.
To Spark plugs...
