Turn Signal Socket
Old Nov 14, 2006 | 10:50 PM
79Vette4spd's Avatar
79Vette4spd
Default Turn Signal Socket
Hello,
My right turn signal works great. When using the left turn signal the front and rear bulbs flash but the indicator light on the instrument cluster does not work. The bulb is good. When I measure the voltage at the end of the plug to the instrument cluster the right side stays around 11+ volts the left side varies from 0 to 8 volts. Is this an indication of a bad socket or grounding problem? How do you test the sockets?
