I have been looking for a correct coil for my '72 BB Auto but to no avail.
I have seen one similar advertised "Without TI". What does this mean please. My car is quite original so would it have TI or not.
No 72 Vette with TI except possibly ZR-1 350 Vettes. TI works by spiking the coil with voltage so construction of coil is WAY different than conventional coil. I would do a proper Petronix breakerless conversion and use their black coil, then your set-up would be better than "TI".
The coil is not original and apart from being made in Mexico has 067 stamped and the words "Use with primary resistance wire or external resistor". Are we therefore saying that it has a "Transistor ignition" ?
