Rear diff ?
Old Nov 16, 2006 | 03:02 PM
crf311's Avatar
crf311
Default Rear diff ?
Hope someone will be able to help me with this question. I am in the process of rebuilding my vette which took on some water during Hurricane Katrina. I removed my rear diff and found out it wasn't a posi unit and needed some work, so instead I purcahsed a posi diff from a fellow forum member. Any way my question is my old diff had the small yoke and my new diff has the larger yoke. What is the cheapest and easy way of correcting the problem. Can I just change the u joints, Or do I need to change the yoke which is on the diff. Or can I swapout the driveshafts? Thanks Robert
Old Nov 16, 2006 | 03:10 PM
bence13_33's Avatar
bence13_33
I don't think you are supposed to remove the driveshaft yokes unless you are going to be rebuilding the rear end. From my understanding it messes up the crush bearing, they are set at a certain torque and once you remove them you won't be able to get the same torque. If possible I would just change the u-joint on your driveshaft accordingly.
Old Nov 16, 2006 | 03:53 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
If I'm not mistaken you can get U-joints that are small on one axis & large on the other
Old Nov 16, 2006 | 05:28 PM
redvetracr's Avatar
redvetracr
You need a Spicer 5-134X u-joint
...redvetracr
Old Nov 16, 2006 | 06:49 PM
68 NJConv 454's Avatar
68 NJConv 454
Nice car CRF311!!!!! you have the rims I want, what are they? type? size? price? very nice vette, I hate thinking it took on water during Katrina. Get'er back on the road where she belongs. Good luck.
Old Nov 17, 2006 | 10:13 AM
crf311's Avatar
crf311
...redvetracr
Thank You very much. . Do you know where I can get one?
Old Nov 17, 2006 | 03:04 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Your local driveshaft shop should carry them. They are also called conversion joints. You need to go from a 1310 u-joint to a 1330 joint.
Old Nov 17, 2006 | 07:25 PM
crf311's Avatar
crf311
Thanks for the info. On A different note I need to give you a call. Before the storm you had rebuilt one of my trailing arms, and I was going to take the other off and send it to you, well the storm hit before I had the chance, Now I want to send the old arm along with the one you had rebuilt. to go thru and rebuild. I will call next week. thanks Robert
Old Nov 17, 2006 | 07:27 PM
crf311's Avatar
crf311
They are Boyd's Blaster 5 I think, 17X8 4" BS. I don't remember the size tires I put on.
To Rear diff ?
