78 Air Cond
Old Nov 16, 2006 | 04:39 PM
MickeyG's Avatar
MickeyG
Default 78 Air Cond
When I purchased my 78 L82 the air cond. belt had been removed and the wiring to the compressor disconnected. The clutch seems to move freely by hand and when I pressed on the shrader valves there appears no freon in the system. I would like to get the air back working but don't know where to start
Old Nov 16, 2006 | 05:04 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The first thing I would do is talk to the previous owner, if possible, to find out the status of the a/c system. If that is not an option, you just need to start trouble shooting. You say the clutch turns freely and if it feels smooth when you spin it, there is a good chance the clutch is okay. I would then turn the a/c switch on, ignition on/engine off, and check to see if the compressor wire has power. If it does, hook it up to the compressor and this should engage the clutch. You should hear a click as the clutch pulley locks on to the compressor. I would then take a wrench to the bolt in the middle of the clutch to see if the compressor can be turned. If it won't move, it is probably frozen up, meaning a bearing has siezed. That would be my guess as this is generally what is done (belt removed/wire disconected) when the compressor goes. Hope this helps and good luck!
