correct position for jack stands or jacking
Old Nov 16, 2006 | 05:40 PM
sjmaster's Avatar
sjmaster
Default correct position for jack stands or jacking
I was going to install my longer rear suspension leafspring bolts tonight. Is there a specific place on the side frame rails the jack stands should be??
Also, are there designated places a hydralic floor jack should be used. I have been lifting the front using the center arched frame area under the engine (justified to the rear to be in line with a vertical member)
Is this OK.?? Thanks !!
Old Nov 16, 2006 | 05:46 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I like using the side frame rails lifting with the jack at each corner leaving enough room to place the stand under the rail. In the front, I also use the lower a-frame at times to support the car, depending upon which area of the car I'll be working on.
Old Dec 18, 2006 | 02:55 AM
78CO_VETTE's Avatar
78CO_VETTE
was researching the same thing and found this new thread:http://forums.corvetteforum.com/show...ght=jacking+up
Old Dec 18, 2006 | 10:27 AM
75 Hot One's Avatar
75 Hot One
Never jack on the front center crossmember. It's not made for jacking & will dent. Proper locations per shop manual are side frame, just ahead of rear wheels and at front about 3" ahead of front door edge.
To correct position for jack stands or jacking
