HEI Shim and Spring Question
Old Nov 17, 2006 | 11:11 AM
79vetter's Avatar
79vetter
Default HEI Shim and Spring Question
Where do you guys get your lower distributor shims from? A local parts store? I tried A-Zone but a no go. If you have a part # that would be nice...
Also, for HEI, Lars recommends the Gold springs from the curve kit however my Mr. Gasket part # 929 only had one in it. Is this normal?
thanks Rob
Old Nov 17, 2006 | 11:20 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I see that CC has shims for the pre HEI distributors. i don't know if they'll help of not.
http://www.parts123.com/parts123/yb....A0~~~~~A40~A31
Old Nov 17, 2006 | 11:22 AM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by Jud Chapin
I see that CC has shims for the pre HEI distributors. i son't know if they'll help of not.
The paste is not working. Anyway, go to CC's web site and go to distributors. Hope this helps.
Old Nov 17, 2006 | 11:53 AM
Hadez's Avatar
Hadez
79vetter....if you don't mind me tagging along. Are you updating/tuning your HEI as per the Lars notes? If so I am planning on doing the same thing in a couple weeks as I have a HEI on my 69 L46 with a converted tach, etc. I would like to know where you are getting your parts from also so I can do the same with my setup. I am a novice at this stuff so any help you could provide to make sure I have all the necessary parts would be great.
Thanks....
Old Nov 17, 2006 | 11:58 AM
Scott Marzahl's Avatar
Scott Marzahl
I just posted this link earlier in the week. A lot of neat HEI parts. The small rebuild kit comes with shims.
http://www.kendrick-auto.com/ignition.htm
Old Nov 17, 2006 | 12:09 PM
79vetter's Avatar
79vetter
Carpedm, No problem tagging along.
That's a great link for HEI parts- they've got everything. I was hoping that Napa or someone else local would have these parts.
Old Nov 17, 2006 | 12:16 PM
Scott Marzahl
Schucks/Kragen/Checker sells Mr Gasket, the Mr Gasket Shim kit # is 2820, they can special order you the spring and shim kits in about 2 days. Or if you have a real speed shop in your area they should have them.
To HEI Shim and Spring Question
