T-tops
Old Sep 22, 2001 | 08:14 PM
ridged84's Avatar
ridged84
Default T-tops
I changed the weatherstripping on my tops . Now when i put them back on there not lined up right. Is there any way to adjust them so the lines are even.BTW it rained like a mother*#%$&#here and it didnt leak. :confused:
Old Sep 22, 2001 | 09:54 PM
CWUin82's Avatar
CWUin82
Default Re: T-tops (ridged84)
I have glass tops on my 82, but I'll assume all are similar to adjust. The tongues that go into the center bar are adjustable. Once you take it apart you'll see how to loosen screws to for the side to side adjustment. (getting the centerline straight). To adjust height, there are shims that you can add or remove for the height. Not a hard job. Hope this helps.
Old Sep 22, 2001 | 11:13 PM
ridged84's Avatar
ridged84
Default Re: T-tops (CWUin82)
Thanks ill try it hope it works
To T-tops
