'75 Power Steering Control Valve
Old Nov 19, 2006 | 07:15 PM
HDFLH67's Avatar
HDFLH67
Default '75 Power Steering Control Valve
I have replaced all power steering components with rebuilt to try to eliminate my power steering leaks. The "new" power steering control valve still appears to be leaking quite seriously. It looks like it is leaking from a little "ball bearing" looking thing on the outboard side at the bottom of the valve, maybe a pressure control release?
Anybody have any thoughts? It drips whether the engine is running or not.
Thanks as always!
Old Nov 19, 2006 | 07:48 PM
Duke94's Avatar
Duke94
Thanks as always!
Send it back where you got it. I went through 3 of them before I got one that didn't leak. They were "new" also.
Old Nov 19, 2006 | 07:53 PM
Glassbowtie77's Avatar
Glassbowtie77
Send it back, is that little ball bearing thingy your talking about possibly the grease fitting? If so, power steering fluid should not be in part of the unit, something internally is not put together right or there is a defective part in there. Either way return it and get another one. If they send you another one and it's still leaking return that one too and try another vendor.
Old Nov 19, 2006 | 09:05 PM
Jim Shea's Avatar
Jim Shea
Is the "ball like thing" right under the stamped end cap? If so, it is a ball bearing that is pressed into a communication passage. It basically is a plug. If it is leaking, send it back.
Jim
Old Nov 20, 2006 | 09:35 AM
Tom454's Avatar
Tom454
Yes... send it back!
And send the next one back.
And send...
Now we know the difference between "new" and new.
Who is paying for all of the shipping on this?
Just curious.
Old Nov 20, 2006 | 10:31 AM
tracdogg2's Avatar
tracdogg2
Is this a new valve or a rebuilt valve? If it is a new valve this is a common problem and easily fixed.
Mike
Old Nov 20, 2006 | 12:44 PM
dgruenke's Avatar
dgruenke
I also went through 3 of them before I got a good one. Send it back.
Old Nov 20, 2006 | 08:32 PM
Sayfoo's Avatar
Sayfoo
Rebuilt parts are getting crappier all the time. I went through 2 rebuilts on a Mustang that didn't leak, but didn't work well either. Luckily, A new unit came on the market (Flaming River). It works fine. I always try to buy new if I can. The worse part is that if you replace 1 part of a system, then assume that part is good, you then think that something else is bad and start changing other parts. Never ends.
Old Nov 20, 2006 | 09:30 PM
greyghost79's Avatar
greyghost79
owning an old vette is kinda like being married. it's never perfect but you keep trying to fix it and enjoy the parts that do work.
To '75 Power Steering Control Valve
