rod bearing question
Old Nov 19, 2006 | 11:33 PM
rick1500's Avatar
rick1500
Default rod bearing question
Don't know much about rod bearings and I don't have my old ones to check anymore, but in looking for new ones from Summit, they show these options:
Dowel Pin Hole: Yes/No
Chamfered Bearing: Yes/No
Grooved Bearing: Yes/No
My rods don't have a dowel pin, so I don't need that. But, I don't know if I need a chamfered and/or grooved bearing. I'm rebuilding a '70 L-46 w/ original rods to stock specs and I'm looking at these:
http://store.summitracing.com/partde...0&autoview=sku
Just wondering if those are OK...Thanks!
Old Nov 20, 2006 | 01:38 AM
Ironcross's Avatar
Ironcross
None of the three above, just use stock bearings. Before you order any, either mike the crank or have someone to do it for you. If there are any groves or scratches in the crank you should probably seek the possibility of a reground shaft. Most of the time all necessary bearings come with a crank kit. Even with the kit, the new shaft should be checked to make sure the sizes are correct. A whole bunch of amatures are working in todays cut rate parts stores that dont know a damn thing if they cant find it in a computer.
Old Nov 20, 2006 | 02:03 AM
rick1500's Avatar
rick1500
OK, thanks...so no dowel hole, chamfered, or groove. I'll just get these then:
I already had the crank and rods checked out and they're ready to go. So what does it mean when rod bearings are chamfered and grooved?
I've really found that to be true. They're good at asking me for the part description, year, make, model, and engine size. Then, they just turn the monitor around to me and I point at the part number while they get it off the shelf. I go to the forum for any question beyond "do you have this in stock"...they've almost never answered a question I've had with any degree of certainty since I started the frame-off almost 2 years ago.
Old Nov 20, 2006 | 02:15 AM
Ironcross's Avatar
Ironcross
The bearing types you dont need are actually the ones I use. We have and use steel billet cranks in my racing engines and they are ground with a radius for strength on the throws so a chamfered bearing is necessary. The dowel pins are used with aluminum rods to keep the bearing from spinning. And groved bearings are most often used on the mains. The CB663P is your correct small block Chevy rod bearing
Old Nov 20, 2006 | 02:49 AM
rick1500's Avatar
rick1500
Thanks for the help!
I checked out your Corvette photos. If I had 3 rats and a mouse, I'd never get to work...I'd never decide on which one to drive!
Old Nov 20, 2006 | 03:03 AM
Ironcross's Avatar
Ironcross
Default Nitro Alley
Thanks,
Try the web site below, if you liked the rats and mouse some different toys are there.
PS, The driving decision is quite simple. Just use the one with the most gas. Sometimes that means use one of the Harleys
Old Nov 20, 2006 | 09:28 AM
Tom454's Avatar
Tom454
...Thanks!
RE: the correct answer above on chamfered...
If the crank has been cut "straight up" without the radius, you need
non-chamfered bearings.
If you do not know the complete history of the crank,
then you need to look at it first before ordering the bearings.
T
Old Nov 20, 2006 | 09:41 AM
L88Plus's Avatar
L88Plus
Go back to the shop that checked the crank and buy bearings from them. They can't be that much more than Summit and you're supporting a local business. If you use "H" bearings - chamfered -on a crank that doesn't have the wide radiuses on the filets, you'll end up hemorrhaging a lot more oil than if you ran a standard "P" bearing since the actual bearing surface is narrower. On the other hand, if you try to run a "P" bearing on a chamfered crank, the bearing will dig into the crank and cause a world of grief. The shop that checked the crank will know what you need, give 'em a shot.
Old Nov 20, 2006 | 11:50 AM
Tom454's Avatar
Tom454
Well said.
Old Nov 20, 2006 | 03:55 PM
shafrs3's Avatar
shafrs3
I don't know if you needed this or not but I thought I might post it just in case.
The first picture is a chamfered crank journal. Look at the edges of the bearing surfaces close to the throws and notice the smooth ramp-up of the bearing surface.
The second pic is a non-chamfered crank, the edges are cut squarely.
Old Nov 20, 2006 | 11:26 PM
rick1500's Avatar
rick1500
Thanks for those pics ...I definitely have a non-chamfered crank.
To rod bearing question
