bolt grades?
I mean, how strong in one grade vs the other? Are there numbers anywhere to compare? :confused:
thanks
I use grade 8 basically for suspension,steering and brakes only, Everything else gets a grade 5. By the way you have mail that you may like to post. ...redvetracr
In short, harder is not always better.
The type of metal and hardness were originally chosen to perform a function. Altering them without knowing why they were chosen in the first place could put you, and others on the road, in jeopardy if that "crucial" fastener fails.
For example, a fastener that normally provides good shear strength may fail if a more brittle, hardened fastener is substituted. Some materials are more prone to hydrogen embrittlement than others. etc
Unless you understand the function, the materials and the process, I'd stick to OEM or equivalent fasteners.
I only offer this advice to avoid :nopity in the future
