Hardtop removal help
Old Nov 20, 2006 | 07:42 PM
ctrain22's Avatar
ctrain22
Default Hardtop removal help
Well, after being n yhe car and not removed for about 16 years, I am trying to get the hardtop off my 70. No matter how hard I puul on the ;atch ahndle, it wil not open the latches in the rear. I tried to adjust the cables, but it didn't help. The latches seem to be frozen. Is there any way to get the top off? Once I get it off, I can free up the latches(I hope). But getting it off is the problem.
Old Nov 20, 2006 | 08:36 PM
...Roger...'s Avatar
...Roger...
I think I would take a light and crawl under rear deck and release each lock manually.I would lift the top a little at the windshield and put some rags in there to put some tension on the rear latches.Oh -you did remove the side mounts didnt you ?
Old Nov 20, 2006 | 08:54 PM
ctrain22's Avatar
ctrain22
With the soft top under there, it's hard to get to the latches. By the way, what side mounts?
Old Nov 20, 2006 | 09:21 PM
...Roger...
There should be a bolt on each side-inside the car.
Check this thread.
http://forums.corvetteforum.com/show...hlight=hardtop
Old Nov 20, 2006 | 10:40 PM
jdunne's Avatar
jdunne
The latches don't work on the hardtop if it is properly installed; there will be 2 or 3 nuts on the rear deck together with one on each side on the door pillar and of course the 3 windscreen head latches....the rear deck ones are supposed to be wing nuts but they are often changed to hex nuts....hope this helps...john
Old Nov 20, 2006 | 11:10 PM
moosie982's Avatar
moosie982
Can you unlock it at the windshield and then unlatch the deck so the whole kitnkaboodle can be opened up ,with the hardtop pointing up, this will let you get a look at what is holding the hardtop to the deck, bring help tho,,I used to do my '71 like that way back when,,,,Peace,, Moosie
Old Nov 20, 2006 | 11:22 PM
jdunne's Avatar
jdunne
That really is the only sensible way to get at the nuts on the deck lid.....don't forget to undo the door pillar nuts first!!!!!...john
Old Nov 21, 2006 | 01:05 AM
another-user's Avatar
another-user
huh... i never knew this stupid things were that complicated. ive just got 2 wing nuts holding it down in the back and the 3 latches in front.
Old Nov 21, 2006 | 01:17 AM
motovate's Avatar
motovate
My 74 has 1 bolt with nut and washers on each side in the back and 3 clamps along the front for the hard top. I also had to remove the soft top completely to get to the hard top bolts. PITA so I leave the soft top out when the Hard top is on and when the hard top is off I put the soft top back in. I have thought about getting the soft top type of studs and put them on the hard top so it works like the soft top with the levers - not sure if that would work. Anyone done that????
LBM
Old Nov 21, 2006 | 07:05 AM
...Roger...
Sorry ctrain had a brain fart On my 66 I did what Moosie said.With the 2 side bolts in place I lifted the whole kitnkabootle,removed the 2 nuts under deck(in your case also the third one in the middle if it is there)then set the kabootle back down and then remove the 2 side bolts.Careful the deck studs dont scratch the deck when you pull them through the deck.
Old Nov 21, 2006 | 10:59 AM
71rdster's Avatar
71rdster
LBM
I have a hard top that the previous owner used soft top studs. The top blew off of the car and was nearly destroyed. I personally would not do it.
Old Nov 21, 2006 | 12:41 PM
MonzaRedConvert's Avatar
MonzaRedConvert
LBM
I've always had mine setup like that with no problems at all. Not sure how it could blow off especially if the side mounts are in place. It seems pretty secure.
Old Nov 21, 2006 | 03:13 PM
ctrain22's Avatar
ctrain22
Thank you all for advice and info. With so little room in there with the soft top, I didn't realize the top was held on with bolts at the latches. Boy do I feel dumb! I will go deeper in there and get them. Thank you all so much.
Old Nov 21, 2006 | 09:14 PM
motovate's Avatar
motovate
Don't feel Dumb. After I got mine with the Hard top on and the soft top bolted in and folded I noticed the rear of the hard top seemed loose so I kept pushing down on the corners to get it to catch. I even went back to the place I bought it from so he could show me how to do it. He did the same thing I did then swore it was hooked up and that he had driven it over 100 miles at speed with nary a problem.
I realized it wasn't bolted down when I unhooked the 3 front latches and just lifted it off. No nuts , washers or anything else holding it in the back. After spending hours contorting trying to get both sides bolted down - I just took the soft top out and bolted it down and decided to just switch them out twice a year - Hard top on for the winter - soft top on for the summer and store whichever top is not in use. The only side bolts are for the soft top on my 74 - the hard top only has 2 threaded studs in the back and 3 clamps in the front. Other years might be different.
LBM
I don't think I'll chance it by replacing the bolts with the studs. It way to spendy to replace if it learns to fly - off the back!!
LBM
Old Nov 22, 2006 | 09:23 PM
TimAT's Avatar
TimAT
My '69 has a stud on each side with a nut and flat washer. No problem to reach over the soft top and remove/install. But in all fairness, I work on big airplanes for a living, and there are lots of things you can see, lots of things you can touch, but lots of things you can't see and touch at the same time..
Old Nov 24, 2006 | 08:01 PM
ctrain22's Avatar
ctrain22
Now to add to complications, I was going to use the advice of openeing the top cover as a unit with the hardtop still on to get access to the bolts. When I went to open the cover, the cables are broken! So I can't open her up anyway. Going to have replenish the beer fridge and figure this one out. Ned to find an access to the cover latches.
Old Nov 26, 2006 | 11:31 PM
jdunne's Avatar
jdunne
There are rods that go from the handle mech to each side latch,they often fall out...easy to reattach them then pull handle....otherwise you'll have to reach over to each latch and trigger it separately...john
To Hardtop removal help
Old Nov 28, 2006 | 10:41 PM
ctrain22's Avatar
ctrain22
Thanks for all the help everyone. Finally got the lid open and hardtop off. Had to remove the latches from the lid a suggested. The latches were frozen solid. Just ordered new ones. Good news was the top wasn't too bad. One small hole that I can patch for now. The top is light beige. Didn't know they made it that color, but....
Old Nov 29, 2006 | 12:09 AM
Green73's Avatar
Green73
They didn't... originals were black or white
Old Nov 29, 2006 | 01:03 AM
jdunne's Avatar
jdunne
Are you sure!!!I am fairly sure soft tops were available in tan for a number of years...john
