Removing Emissions
I there anything emissions related that is required for performance purposes. What vacuum hoses are required other than the ones for brakes and distributor? Any advice that members can share would be appreciated.
You can remove the smog pump and everything it is connected to, the egr and the cat. You might as well ditch the stock air cleaner in favor of an open element. With the stock hood you might run into clearance problems with an airgap intake though.
Don't know if you have a state inspection or not, but removing any or all of the above is against federal law. With that said, hope you make it onto the road next summer.
I run an Edelbrock Performer 2101 on mine with a Q-Jet and a 14x3" open air cleaner, it is a non-EGR manifold and it fits under the hood with no problem. I don't think you'll see any gain with an Air Gap on your stock L48 over the performer anyway. I stripped my '77 L48 of all the emissions stuff and run headers and true duals with 2-1/2" pipes and it did make a difference over stock. The only thing that I left connected is the Evap canister, it keeps the garage from smelling like gas after you drive it and it doesn't effect performance. I still have my PVC connected as well and a chrome breather on the passenger side valve cover, because you have to let the crankcase breathe. The biggest improvement you'll see however is by getting your timing and carb tuned properly.
So, if I assume that the intake has been replaced and all emissions equipment has been removed, what vacuum lines will still be connected and where should they be connected? Will I need to make major adjustments to my timing and carburetor?
I run an Edelbrock Performer 2101 on mine with a Q-Jet and a 14x3" open air cleaner, it is a non-EGR manifold and it fits under the hood with no problem. I don't think you'll see any gain with an Air Gap on your stock L48 over the performer anyway. I stripped my '77 L48 of all the emissions stuff and run headers and true duals with 2-1/2" pipes and it did make a difference over stock. The only thing that I left connected is the Evap canister, it keeps the garage from smelling like gas after you drive it and it doesn't effect performance. I still have my PVC connected as well and a chrome breather on the passenger side valve cover, because you have to let the crankcase breathe. The biggest improvement you'll see however is by getting your timing and carb tuned properly.When I last drove the car 10 years ago it ran perfectly but it was a dog. I just want it to be more responsive. Maybe put me back in the seat a little and possibly break the tires loose. I also want the engine compartment uncluttered.
Please let me know what adjustments you had to make after removing the emissions equipment and what challenges you encountered during the process. Any advice would be greatly appreciated.
You need to have your Quadrajet rebuilt/upgraded like Lars has done in the past. You should decide on the cam change early in the process so that all changes will match.
The only vacuum hoses left are for headlights, other than power brakes, vac advance etc.
See my sig for other changes on my car.
If your interested in selling those parts your taking off let me know.
I have a 77 I need to get passed for smog in California.
tt
If you don't have PCV you will probably develop oil leaks all over the place. Doesn't hurt performance - probably helps.
How are you going to register your Vette? Classic / Antique or regular.
It may make a difference.
I registered mine as an Antique and don't have to worry about state insections. Another guy registers his 69 as a regular vehicle and has to get annual inspections. The place he took it said they would not pass it because he had an open air cleaner instead of a closed one and did not have the heat pipe that goes from the exhaust manifold to the air inlet.
We have pictures from the AIM and NCRS judging book that says big blocks never had the heat pipe and some big blocks and all LT1s had open air cleaners. No deal. They didn't even notice he doesn't have the air injector.
