Backfire
Old Nov 21, 2006 | 12:55 PM
genuine1980's Avatar
genuine1980
Default Backfire
Highway driving, 80 mph or so, I take my foot completly off the gas while leaving the car in gear to coast up an exit ramp or whatever. While coasting like this, I hear a popping or backfire through the exhaust. It will only do it while still at a decent speed... It wont do it once speed is below 60.
What could this be?
If I am unclear let me know where and I will try to explain better.
Old Nov 21, 2006 | 01:11 PM
delamorajc's Avatar
delamorajc
Default Backfire ---
My car is backfiring at the same time and also when I start her but mostly when I take my foot off the gas. I just replaced the carb, wires and distributor cap + rotor and exhaust system once I fire her up I will let you know if this fixed the problem.
My sugestion for you (from a novice) is to review your carb, exhaust and wire config. possibly change out your plugs but I'm not an expert just new to motors in general and limited knowledge based on my similar problem.
good luck.
JC
Old Nov 21, 2006 | 01:20 PM
genuine1980
good luck.
JC
The only time I get this backfire is when I take my foot off the gas while going fast... I have a manual tranny so I would suppose it would also do it at slower speeds if I downshift and get the engine at high rpm. But never at startup, idle, low rpm downshift, low speed, or while on the gas.
Old Nov 21, 2006 | 03:32 PM
genuine1980
ttt
Old Nov 21, 2006 | 05:57 PM
gerry72's Avatar
gerry72
You have a leak in your exhaust system.
Old Nov 21, 2006 | 06:05 PM
stingr69's Avatar
stingr69
Do you still have the smog pump? Air in the exhaust can do that.
-Mark.
Old Nov 21, 2006 | 08:30 PM
genuine1980
IS this anything to worry about?
Old Nov 22, 2006 | 09:02 AM
genuine1980
I'm not sure if I have a leak or sucking air into the exhaust. I have headers that are nice and tight and have new gaskets, that connects to a straight exhaust pipe (again tight with new collector gaskets), to the mufflers which are welded on.
I just dont see where I can have a leak... any ideas? Or is this backfiring possibly something else?
Old Nov 22, 2006 | 09:11 AM
TJ76's Avatar
TJ76
In the past I had the same situation. I was told by a very confident person that it was lean on deceleration. I tweeked the idle mix screws a tad and it went away. There could be other fixes, like recurving your dist. or richening the low speed jetting. But mine was idle mix. Good luck.
TJ
Old Nov 22, 2006 | 10:09 AM
stingr69's Avatar
stingr69
Yes, you can destroy the mufflers.
-Mark.
To Backfire
