Radiator weatherstripping
Old Nov 21, 2006 | 03:59 PM
Berserker78's Avatar
Berserker78
Default Radiator weatherstripping
When I replaced, my radiator with a 3 core, I had to pull the old weatherstripping off to make it fit. Now that I have the system figured out, I want to put some weatherstrip back in, but I am unsure what pieces I need.
Can I use a BB weatherstrip set? Or will I need to just measure the spaces and buy cheap stuff the right thickness?
Old Nov 21, 2006 | 07:20 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Is the replacement radiator the same size as the original? If so, then you can get a radiator seal kit from almost any of the vendors. If you went with some other size radiator, you could call the vendor help line and get something close in a radiator seal kit, but you might have to do some cutting and tweaking. The main goal is to force the air through the radiator instead of having air flow around it. Going through the radiator will keep operating temperatures where you want them. Good luck!
Old Nov 21, 2006 | 10:37 PM
markdtn's Avatar
markdtn
76L-81 all have the same core support, so I would just buy a radiator foam kit from Dr Rebuild or 1 of the other catalogs and it should work fine.
To Radiator weatherstripping
