I am going to order the Pertonix Ignitor II and Flame Thrower II coil, I was wondering if anyone is currently using this setup and if they were satisfied with the results.
Just put mine in today. So far so good. After reading several things here I wish I had recurved the distributor at the same time. (See some of the tech articles on timing in the archives by Lars). That's for another day I suppose. I do like the Ignitor II, however, and I think it's a great value.
Put in the "Lobe Sensor" unit and Flamethrower coil 3 weeks ago, so far am very pleased. There is a small inconvience with the Lobe Sensor, you have to turn the key to the ON position for 5 seconds before starting or the engine just cranks and cranks (have forgot the 5 second deal a couple of times :eek: ). Install took all of 15 min including checking the timing. Time will only tell.
Put both in a couple of weeks ago and love them. The install was easy too.
Ditto (actually a few months ago for me). Make sure your distributor is in top shape before you install. No point in using a hi-tech electronic gizmo if there is a lot of slop in your stock dist. check: vac advance, springs, advance slots and bushings, and end-play.
A great investment....I like mine very much.......great performance at an very reasonable price...Go with retrorockets for the best price around..go to http://www.retrorockets.com
