I'm studying to be a mechanical engineer, and for my design class project I'm supposed to collect some surveys relating to Car Ramps (ie the wedges you drive up on to raise your car). Basically we're trying to design a new ramp out of a special recycled plastic.
I was hoping some of you guys would have insight you could share about physical or functional requirements.
Anyone have any comments relating to these questions?
1. What do you like about drive up ramps.
2. Why/when/where do you use them?
3. What don't you like about them?
4. Any ideas for improvement, features or enhancements you'd like to see?
i know the problem i have is that the front on the car hits the ramp before the tires do..... so you almost nee a shallow run in the beginning then slop up gradually.........a concave slope then level out....
why does it have to ba a ramp.... why not a set of stacked levels.... like stacked 2x8s......
Pretty much the only problem I see is that the spoiler hits the ramp before the tire does on a low car like the C3, but it also does on my '04 Cavalier. Another minor issue is that wide tires sometimes don't fit nicely. Good luck with your project.
The main reason I don't like the car ramps you drive onto is that almost every single garage has a somewhat slick concrete floor, and of the two sets of car ramps I've used (one metal and one some type of plastic) slide out from under the tires when you try to drive onto them inside the garage, the ideal place to use them, so what I have done in the past is take 2x4s and put one end against the wall and the other end against the ramps to get on them, but they still slip out when you back off. So, when using car ramps I have always had to use them outside in the driveway. I almost never use mine.
1. a.you don't have to jack up the car and use jack stands. b.they compress the suspension by keeping the vehicle weight on the wheel
2. use them in the garage when I need the suspension compressed
3. a. I agree that the biggest issue I have is a ramp has an angle that is too steep for a low or long nosed car drive up without hitting it. b. aligning the ramps parallel to the car can be difficult in confined spaces.
4. a. Ramps should have positive stops or depressions to keep from driving off the end. b. cheapy laser pointers could be used to help align the ramps. c. mirrors on the front/outside of the ramp would help the driver see where he is on the ramp without needing a second person to spot for you.
Good luck on your design project. Are you going to cite the forum in your report? Also, I have a compact solution to 3.a. but you should do some of the work, eh? Show us what you come up with. Go Huskies (even though I didn't attend U dub my childhood was spent in Seattle)
