I'm going to cry.....
Old Nov 23, 2006 | 11:47 PM
  #41
okinawa86vette's Avatar
okinawa86vette
Originally Posted by bobs77vet
...have you taken your distributor apart to ensure everything is working properly?
I've only taken the cap off. It looks fine...no carbon tracking, excessive wear or anything like that. Doesn't look brand new, but nothing that would indicate a problem.
I haven't pulled the distro out again though. With the pertronix in there, there really isn't much too look at. Just the rotor, ignitor module and the magnet...not much else.
Oh, and a friend of mine has a 750cfm edelbrock carb on his '68 Firebird, so we're going to swap it in and see what happens. Obviously, it'll be pretty rich, but it should at least eliminate or confirm the carb as the problem.
Chris
Old Nov 24, 2006 | 12:24 AM
  #42
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Hi guy's I am a pro. mech. are you sure your not leaking vacum through the intake manifold gask into the valley. sometimes these leaks can make a ticking noise. Are you useing the proper gasket for the type of intake your useing? If it runs fine for 30 or so miles then acts up did you try retorqueing the intake?
Old Nov 24, 2006 | 12:43 AM
  #43
okinawa86vette
I'll try retorquing it again, but it didn't do anything with the problem when I was running the last set of heads. It's worth trying again this time.
The intake gaskets are what's recommended by the intake mftr.
Chris
Old Nov 24, 2006 | 05:54 PM
  #44
okinawa86vette
Alright, I swapped carbs with my friend's Firebird.
His ran great with my carb and my car still ran the same. So it's not carb related.
Here's a thought....Could it be possible the intake manifold is cracked? It's a Weiand 8004 aluminum one.
Chris
Old Dec 26, 2006 | 10:24 AM
  #45
c3t2's Avatar
c3t2
Chris
Old Dec 26, 2006 | 10:33 AM
  #46
c3t2's Avatar
c3t2
Chris - I have a 72 with the same problem - rebuilt engine with less than 1000 miles - new heads - comp cam - alum intake - eldenbrock carb. Radically pulsating vacuum readings at idle - steadies out when applying gas. I have changed out the alum intake for the stock and still have vacuum readings as you have described. I believe my problem is the seal between the heads and intake - sucking oil through the bottom of the seal into the runners - basically a vacuum leak - I have noticed that my intake gasket looks oil soaked at the edges. I will pull the heads to see if they have been decked/milled and see if that is causing the misalignment.
good luck
t2
Old Dec 26, 2006 | 11:32 AM
  #47
GDaina's Avatar
GDaina
I wonder if you have a worn cam lobe
Old Dec 26, 2006 | 12:06 PM
  #48
Pusher's Avatar
Pusher
Has the problem been solved? If so, what was the issue? Your last post was a month ago, just curious...
Old Jan 1, 2007 | 07:17 PM
  #49
gordie1465's Avatar
gordie1465
Default missing
check your head gaskets you may have a warped heads also do a leakdown test to find the loss of vacuum may not be electric intake gaskets or more likely head warpage and it happens alot.
Old Jan 1, 2007 | 08:29 PM
  #50
metheglin's Avatar
metheglin
This is like my favorite TV show that shuts down for the summer... I wanna know what happens next!?!
Old Jan 1, 2007 | 08:59 PM
  #51
strokervette's Avatar
strokervette
Mabey there's a rag or something that was left in the pass side intake runners and is now partially blocking the runners.
Old Jan 1, 2007 | 10:24 PM
  #52
Big2Bird's Avatar
Big2Bird
Well, I just read this whole thread for the first time. I had a similar problem once, so here goes my 2 cents. Bad lifter.
Works fine when oil is cool, but collapses when oil thins out. Common to all his symptoms. Can't wait to here what they find.
Old Jan 2, 2007 | 01:37 PM
  #53
sly vette's Avatar
sly vette
#4 and #8 cyl.bad...I still say Ignition..
I got my ears wide open on this one!!!
Old Jan 2, 2007 | 04:41 PM
  #54
jaggeedfire's Avatar
jaggeedfire
Im for leaking intake!! as I have had the same issue before. Upon having erratic vac. on all ports for so long I ended up replacing teh new Edelbrock intake with another and using Permatex Right Stuff sealer I found that the "old" intake was warped although maybe 2 thousanths was enough to not seal properly to the heads and caused all kinds of erratic problems from timing to A/F issues. I would take the intake off again and triple check the trueness of the intake. Also this stuff http://www.permatex.com/brand_right_stuff.htm saves lives...or nerves!!
-Nick
