How to remove Door Handles?
Old Sep 23, 2001 | 10:34 PM
Paul 75 L82's Avatar
Paul 75 L82
Default How to remove Door Handles?
Well, after 4 week-ends of stripping I'm ready to move on. I had masked around the door handles when I stripped the doors. Today I removed the door panels to be able to remove the handles. After a long struggle I got the 2 nuts off of the handle, but I can't see how to remove the linkage to be able to remove the handle. Also I sure can't see how to remove the door locks. I was working with the window down, do I have to remove the window to be able to gain access to these parts.
Old Sep 23, 2001 | 10:58 PM
GaryS's Avatar
GaryS
Default Re: How to remove Door Handles? (Paul 75 L82)
The door locks are held in by a spring clip that is slipped over the back of the door lock. It is a very tight fit and is best removed carefully but with a bit of force. If you will shine a bright flashlight into the interior of the door you will see this "U" shaped spring clip.
The exterior door handles have a rod that hangs down and connects to the door release mechanism. These rods are held to the bottom exterior door handle by a bend in them that prevents them from falling out. Then this rod is held to the door release mechanism by a special clip. YOu must first slide the black spring clip away from the top of the door rod and then the rod will drop down. This clip has a slot in it and the head of the rod has a groove in it. You push the rod up through the clip, just enough to get the groove in the rod into the slit in the clip. Once you see how it works it becomes obvious. That doesn't mean that it is easy, just obvious. ;)
Gary
Old Sep 23, 2001 | 11:09 PM
Paul 75 L82
Default Re: How to remove Door Handles? (GaryS)
Thanks for the info Gary. I will look at it again tomorrow and maybe I'll see what your saying. It's amasing that with each new project we have to learn so many new skills,removing a door handle is sure one of them.
Old Sep 23, 2001 | 11:10 PM
GTR1999's Avatar
GTR1999
Gary covered it well, I would just add that to get the handle nuts on/off it's easier to remove the door latch assembly first. You can then get at the nuts better and the lock clips. You could also get the latch assembly cleaned and lubed to eliminate any opening problems.
Gary
Old Sep 24, 2001 | 02:43 PM
KenSny's Avatar
KenSny
Yes, interior work is a whole new set of skills.
I would go to your local auto parts store and get a door handle/window crank removal tool. It will slide behind the part and you can push off the clip. It is a PITA to get off any other way......
To How to remove Door Handles?
