Distributor Disassembly ?
Old Nov 23, 2006 | 08:46 AM
79vetter's Avatar
79vetter
Default Distributor Disassembly ?
I am simply trying to shim up my distributor shaft on my '79 but I don't see how it comes apart. I knocked out the horizontal pin that goes through the gear and removed some of the screws at the top but I;m not sure what is the next step. My Service Man. doesn't go into detail on this and I didn't see a Lars paper on this one...
Old Nov 23, 2006 | 09:20 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
the shims should go between the gear and the housing. no need to remove any screws to take the play out.
Old Nov 23, 2006 | 09:23 AM
79vetter's Avatar
79vetter
Yes, but how do you get the shims on. Something must come apart...
Old Nov 23, 2006 | 09:33 AM
Richard454's Avatar
Richard454
The gear SHOULD come off -if the pin is out-but it might take a little force. A piece of wood, hammer and a little PB Blast should be all that's required.
Old Nov 23, 2006 | 10:23 AM
spedaleden's Avatar
spedaleden
Here is a rough picture of what to do
.010 - .015 Movement between gear and dist housing
Pull the pin on dist gear and slide gear off. Slide shims on shaft and replace gear and replace pin.
Hope this helps
Old Nov 23, 2006 | 10:37 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I love the diagram Spedaleden. Better than any written description you could've given. I wish some other fixes were as simple to describe.
Old Nov 23, 2006 | 11:36 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
Remember to line the dimple on the gear up with the rotor whemn you put it back together.
Old Nov 23, 2006 | 11:40 AM
79vetter's Avatar
79vetter
Thanks guys, a hammer helped the gear to come off...
Should the feeler gauge go in fairly easily when measuring or it is accurate when the gauge is snugly in ?
I'm also open to advice on getting the distributor to go down the last 1/8" when installing it...
Old Nov 23, 2006 | 12:06 PM
spedaleden's Avatar
spedaleden
I had to play with the oil pump shaft. I turned it 1/4 turn counterclockwise and it slipped right in. Make sure the rotor lines up in the exact spot as when you took it out. You don't want to be a tooth off.
Old Nov 30, 2006 | 08:11 PM
David Ey's Avatar
David Ey
If the dist is almost down and the rotor is positioned properly all you need to do to get the sucker to engage with the oil pump is crank the motor over and she will drop right down.
To Distributor Disassembly ?
