Low pressure return hose (for hydroboost)?
Old Nov 23, 2006 | 07:42 PM
nihil's Avatar
nihil
Default Low pressure return hose (for hydroboost)?
What sort of hose should I get for this? I figured I'd just go with what is used for the return from the power steering control valve, but I can't figure out what that is.
Also, are any specific clamps recommended, as well as the "T" connector for the hydroboost and control valve returns lines? Any help is great, thanks!
Old Nov 23, 2006 | 08:04 PM
mrvette's Avatar
mrvette
I use a metal 3/8 T fitting.....clamped hoses.....
Old Nov 23, 2006 | 08:07 PM
nihil's Avatar
nihil
What kind of hose did you use?
Old Nov 23, 2006 | 08:21 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Oil proof hose (fuel line). There is minimal pressure on this hose, so regular clamps are fine. Just a brass tee I got at Auto Zone.
Old Nov 23, 2006 | 08:32 PM
nihil's Avatar
nihil
Thanks.
To Low pressure return hose (for hydroboost)?
