hmm... so whats the difference between 17x8, 16x8, and 17(or 16)x6 on the front? do you gain/lose anything in any of these setups with the same size rear wheels on all of them?
I think theres someone on the forum with 17x9.5 front, and 17x11 rear TT2's... Thats what i'm thinking of doing. Would I gain/lose anything with different front setups? (maybe weight distribution or something?)
Also, can you go any bigger than 11" wide on a c3?
Ahhh, I was wondering why they have bicycle wheels on the front (exaduration).
But if I plan on both street cruising & drag racing, I should get some nice size front and rear.
Ok, so my last question would be, what do you gain/lose between a smaller height in the front? (ie. 16's in the front, 17's in the rear, instead of 17's all around)
I'm planning on an overall height difference of the front tire wheel combination vs the rear combo in the neighborhood of 1/2". I want a slightly shorter setup up front soley for looks. If you look at the specs on the C5's with 18's in the rear an 17's up front, the overall height difference is 3/4" - 7/8" shorter up front. I'm not sure why they did that, but I'm sure they have a good reason.
