Why do my front brakes pull to the left? Hit the them swiftley the car practicly turns it's self. New stainless calipers new hoses and new pads? Any ideas?
Bad Caliper or brake fluid leaking on to rotor. I had that problem. Brass fitting into caliper was leaking and fluid was splashing on to rotor. Replaced brass ring and good to go.
if you are sure you have all of the air out of the lines and no brake fluid leaks, you may have oil, grease or brake fluid on the brake pads and /or rotors, when mine did that i got a spray can of brake cleaner and it took the oil off my pads and rotors. problem solved. i hope yours is that simple good luck
I agree, if all the parts are relatively new, then the pads are contaminated. If they are not, then check to see if you get good fluid pressure out of the bleeders. Open the bleeder and have someone apply pressure to the brake pedal. Could have a defective proportioning valve or a kink in the hose. Dont use a cheap set of pads either. Always use a good brand name, the cheapies are get what you pay for all the time.
good luck.........
If the pull didn't occur before you changed parts, something is amiss with your install...recheck everything you did, re-bleed and look for leaks...
If the pull occured before you put in your brakes, check out your front end suspension/bushings. Worn bushings will casue the car to veer upon braking.
