A/C Removal on 75
Old Nov 25, 2006 | 09:53 AM
electricblue's Avatar
electricblue
Default A/C Removal on 75
Just Picked up a 75 not working probably no Freon, I would like to just remove the whole assembly along with AIR Pump and hose
anyone have photo of web link on process & bypass ETC
Thanks in advance
Link
http://www.corvetteforum.net/c3/electricblue/
Old Nov 25, 2006 | 10:08 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
AC - Just take it off, no bypass or anything, unless you are talking about taking out the evaporator, too. That is another can of worms & shouldn't be done without researching this site 1st. Air Injector - remove & plug the manifold injector ports with pipe plugs.
Old Nov 25, 2006 | 10:13 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Out of curiosity, why do you want to remove the a/c parts. All you need to do is remove the a/c belt which accomplishes the same thing. If you remove all the a/c parts and want to sell the car later, it will significantly lower the car's value unless you reinstall everything, which is quite a bit of work. (Just my 2 cents.)
Old Nov 25, 2006 | 03:27 PM
electricblue
Thanks for the responce Guys
Ratflinger What about the Hose from consendor to Evaporator
To A/C Removal on 75
