78 turn signal
Old Nov 26, 2006 | 01:09 PM
Rclarendon's Avatar
Rclarendon
Default 78 turn signal
My left turn signal works fine but all of a sudden the right signal does not work at all. No lights inside or outside. Any clues.
Old Nov 26, 2006 | 06:45 PM
cmac72's Avatar
cmac72
Here is a stupid scenario - maybe both bulbs are burnt out. One went awhile ago unnoticed and when the other one went there was nothing left. Did you pull the bulbs and throw a voltmeter from one of the two buttons (for combination lights) to see if you are getting pulsating voltage to the lights? When you put on your emergency flashers, do the same two lights not work? Try the easy things first.
Old Nov 27, 2006 | 12:33 PM
Rclarendon's Avatar
Rclarendon
Default 78 turn signals.
I went out this morning and both turn signals work great. Dirty switch or bad ground? As usual start from the beginning and trace the problem. Flashers are working great. Thanks for your help.
To 78 turn signal
