Higher 1/4 Mile MPH, but same time E.T.
3/30/01 - 14.331 - 99.07
3/30/01 - 14.231 - 99.58
9/8/01 - 14.370 - 101.14
9/22/01 - 14.546 - 102.27
9/22/01 - 14.358 - 103.48
9/22/01 - 14.273 - 103.73
Also… are you flashing the converter or bringing it up to stall speed at the launch?
As far as the Carb goes, I have a Carter AFB 750 and it doesn't have the butterfly on top, it was removed before I got it. The problem I had originally is that it didn't open all the way, I think I have fixed that because my times are much better now. I think that the carb is not set up right though. I need to get a book or something on how to tune it with different size whatevers that go in it but I really am out of my leauge when it comes to that.
For the torque converter, I press the brake at the line, and rev my engine until the car feels like it is going to start moving then keep it at that RPM until the last yellow and I take off like a turtle.
Tuning - My car is in a constant state of tuning, this could also be a reason for the variation of times and MPH flux. I feel like as I learn more the better I can tune the car. I read something here and run out and try it on my car and I feel like all of these little baby steps are working me towards my low 13 sec car that I know I have. The biggest problem I have right now is my rocker arm nuts keep loosening up. I have to retighten them at least every 300 miles ( about 2 tanks of gas ). I just went out and bought new locking nuts and it seems to not have made any difference and they will loosen up to the point where the rocker arms come off of the push rods. The other issue with this is that some of the nuts are really really really tight and some are really loose. I thought that it was a defect of the nuts that were on there but it is the same with the new ones that I put on also, the ones that were tight are still really tight and the ones that are loose are still really loose. I guess it is a defect in the studs that come out of the heads which suck as they are only about 6 months old and I have been having the same problem the whole time with them.
As for the timing, I don't quite get your description, but I'd check to see what kind of vacuum you had at the advance first (assuming it isn't a full mechanical advance distributor). If it is direct (you can feel vacuum from the hose at idle), switch it to ported (so that you feel the vacuum as you rev it up). Play with the timing so that you ge just a slight ping on pump gas (fully warmed up under hard acceleration) and back it of a couple of degrees. This is assuming the mechanical weights in the top of the distributor are stock and working. This will affect street gas mileage, so you might want to switch it back when you're done, but I doubt it! The butterflies that were mentioned by Banshee 63 are the lower ones in the carb itself. With the engine OFF, have a helper give it full throttle and hold it. Look down the primary and secondary bores and see if the plates are wide open. You would be surprised how many I've seen with floor mats and carpet crammed under the pedal, restricting full travel! The problem with this is, it should now spin the tires off the line, which kills 60 ft times! :yesnod: I guess it would be a start...
Mess with the jetting last. AFB's have a great jetting system, that basically requires their "track pack" of jets and metering rods. It is an assortment of jets and rods, that can be changed on the car, between rounds.
I hope some of this helps. It can get a bit more technical, but it's a start. Hammer down!
Hans
From the Edelbrock website.
Duration at .006 Lift: Intake 308° Exhaust 318° Centerlines
Duration at .050 Lift: Intake 234° Exhaust 244° Lobe Separation: 112°
Lift at cam: Intake .325 Exhaust .340 Intake Centerline: 107°
Lift at valve: Intake .488 Exhaust .510
Timing at .050 lift: Open Close
Intake 10° BTDC 44° ABDC
Exhaust 59° BBDC 5° ATDC
My distributor is a MSD tach drive distributor. I haven't played with anything under the cap and have actually never taken the cap off of it. Sounds like something to check out. The way I set my timing is to hook up my timing light, set it to 36 degrees advance, rev the engine and turn the distributor until the lines line up on the harmonic balencer and the guide on the engine. I will try the move up my timing till it pings approach and see what effects that has on everything. As far as gas mileage goes, it sucks now anyway (around 8 mpg) so that doesn't really concern me. AH HA! I understand what you are saying about the butterflies now, I will also check that when I get home. Thanks for the advice on the locking nuts for my rocker arms, I will see if can find some of those. Another question on that also, if I never got the nuts tight enough in the first place, would it be easier for them to back off? The way that I have adjusted them after trying many different ways posted here is to take off the valve covers, check to see if any are loose, if so, tighten to zero lash plus 1/4 turn, bump engine, keep checking, keep bumping .... The downfall to this is that when I am done, the car barely idles. Regardless of which method I use to set the valve lash, it always barely idles and I start just loosening up and tightening different rocker arms until it idles smoothly again.
http://www.edelbrock.com/automotive/7101pp.html
I may have miss understood on the distributor. Does it have vacuum advance or is full electronic? I'm not familiar with the MSD systems (Old fartitis!).
Hans
Hans
tighten it down locking the first one in place.
I just did the math. Going for 8 seconds at 80mph will get you as far as 0.18mls. Which means for making an 8sec 80mph pass you'll have to run about 120mph at the start line and then hit the brakes :D
Hans
All you really need is a higher stall convertor. So you can get into the power range faster. Norris ask me about my 3000 stall - I told him that without a big oil cooler and lower gears I would not recomend it without a lockup switch.
