need to lower rear
Old Nov 27, 2006 | 10:53 AM
mandm1200's Avatar
mandm1200
Originally Posted by steve dalla
i saw a post 2 weeks ago about tightening spring bolts can someone explain how that works and give me a how-to lesson? thanks
You want to loosen the nut. Determine how much you want to lower the car. If there is adequate threads left on the spring bolt, then loosen it. If there is not sufficient threads, then a longer bolt is needed. Measure the length of the existing bolt and purchase one 2" longer. It's somewhat tough to get these bolts at a hardware store. I recommend using one of our fine forum vendors for the purchase.
Old Nov 27, 2006 | 11:32 AM
steve dalla's Avatar
steve dalla
Default need to lower rear
hello i need to lower the rear of my c3 to get rid of ugly fender gap. do you rec. getting a new spring or can i just use old one? i saw a post 2 weeks ago about tightening spring bolts can someone explain how that works and give me a how-to lesson? thanks
Old Nov 27, 2006 | 11:40 AM
panic's Avatar
panic
i have a 10'' bolt with FG spring...
dont know if with stock spring it'll work though....
Old Nov 27, 2006 | 04:15 PM
FKING1's Avatar
FKING1
On my 70 the original spring bolt was 1/2" x 6-1/2". I bought a Grade 8 1/2 x 8 from a local fastener shop which lowered the rear 2". Make sure to get a Grade 8.
Fred
Old Nov 27, 2006 | 04:26 PM
mr303's Avatar
mr303
I recently purchased some longer bolts from a large US vender (I won't name them) and they had made in china stickers on them!!! So be carefull about where they come from, obviously I wont be using the ones I have! Who knows what grade they really are? I doubt there true grade eight.
Old Nov 27, 2006 | 09:26 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The spring bolts on my 69 were 9/16. I bought some 9/16x8in long from the local catapillar dealer for 3.33 each. These are grade 8 bolts and no problems.
Old Nov 28, 2006 | 12:08 AM
clintwilson's Avatar
clintwilson
Default rear end height
Loosening bolt lowers height. Or get longer bolt.
Old Nov 28, 2006 | 06:43 AM
fl_rider's Avatar
fl_rider
Originally Posted by c69vete
The spring bolts on my 69 were 9/16. I bought some 9/16x8in long from the local catapillar dealer for 3.33 each. These are grade 8 bolts and no porblems.
I got my bolts at the local CAT dealer too. The price was right and it settled the rear down to where it belonged.
Old Nov 28, 2006 | 06:59 AM
silver 76's Avatar
silver 76
I got some advise from Fast Corvette about seting the hight. First look from the back at the half shafts ,set the hight so the outer ends are about .375 in. lower then the inside so that when you punch it the h shafts will be stright (not puting stress on the u v joints) then adjust the front hight if necessary.
To need to lower rear
