Holly Carb
Old Nov 27, 2006 | 04:39 PM
Hybrid117's Avatar
Hybrid117
Default Holly Carb
Can anyone tell me how to tell what kind of carb i have, I know its too big and i think its like a 750 double pumper but is there any where on the carb were it would have a model number? I need to get rid of it and get a 600.
Old Nov 27, 2006 | 04:42 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Should be a part number on the air horn that you can see from the front
Old Nov 27, 2006 | 04:58 PM
Hybrid117's Avatar
Hybrid117
thanks gary
Old Nov 27, 2006 | 05:35 PM
gerry72's Avatar
gerry72
The stamping right after the word LIST is what you need. From there, you can go to Holley's site under TECH and look up the carb.
Old Nov 27, 2006 | 11:07 PM
bondoboy's Avatar
bondoboy
If you open the throttle all the way with the engine off, do the secondaries open? If so it's a double pump. There will also be an accel. pump on the rear bowl. Otherwise the secondaries will be opened by a vacuum diaphragm on the pass. side of the carb. The model number will help more, but this info may help narrow it down.
To Holly Carb
