Starter motors????
Old Nov 27, 2006 | 06:25 PM
sjmaster's Avatar
sjmaster
Default Starter motors????
A couple of mundane...but ever so important questions on starters....
1. Are rebuilt starters for 40.00 OK....or are then prone to failure?? I don't want to turn that key and have nothing happen!! Many years ago I went through three 351 Ford rebuilt water pumps before I got one that did not make noise...too many bolts on those.!
2. A NEW OE style starter is 190...200 can't remember exactly. Should I plan to purchase this, or purchase one of the geared high torque starters for same cost?? Do the geared starters have the same turn over RPM??
Thanks!!
Old Nov 27, 2006 | 06:45 PM
mstanton's Avatar
mstanton
I'm not sure what $40 rebuilt starter you're refering to, but I had the original starter on a 71 that I use to own rebuilt and it worked great for 3 years until I sold the car.
Old Nov 27, 2006 | 06:48 PM
gofastvette's Avatar
gofastvette
A 40 dollar starter may not be the best buy you could make. It depends on the builder. Many starters and even alternators are built with cost as a cryteria due to competition from discount stores. There are also heavy duty starters using the same cases. I would suggest a local rebuilder and go see him, nix on the discount junk.
Old Nov 27, 2006 | 07:06 PM
sjmaster's Avatar
sjmaster
Thanks....yes, I was referring to Advance Auto Parts. The 40.00 was with core exchange ofcourse. I don't believe 40.00 could cover the remanufacture's cost and the reseller profit, with any resonable level of quality.
Any comments on geared high torque starters??
Old Nov 27, 2006 | 07:11 PM
mstanton's Avatar
mstanton
I had mine rebuilt by a local rebuilder. I watched while he did it. It took about 20 min and cost $60 in 2002.
Old Nov 27, 2006 | 10:02 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i had a local rebuilder do mine and it is still in the car and works fine. i had it rebuilt in 92 and i drove the car everyday untill 2001.
Old Nov 27, 2006 | 10:35 PM
Jim_Harrison's Avatar
Jim_Harrison
I got tired of buying Delco rebuilts every year due to header heat and bought a small geared starter for a late model GM V-8. It weighs a lot less, starts the car jsut fine and has made it through one year. I think it was around $100. A lot cheaper than the geared starters sold for much more.
Old Nov 27, 2006 | 10:53 PM
greyghost79's Avatar
greyghost79
if you can, go with a gear reduction mini-starter. smaller, lighter, stronger, tougher, better built. you'll never be sorry. summit (among others) has them fro about 150 and up. i have a powermaster mini XS. absolutely great.
Old Nov 28, 2006 | 12:34 PM
Hvymtlc5's Avatar
Hvymtlc5
You can get the mini starter clones on ebay for about 70.00. Mine works great and cranks my big block much easier than the OEM ...and it weighs way less too.
Old Dec 5, 2006 | 06:32 PM
GPD's Avatar
GPD
I am looking at getting a gear reduction starter.
Does anyone know how many teeth a 69 350 w\auto flywheel has?
Can anyone recommend a brand and model that would work well?
To Starter motors????
