dumb gas tank question
Old Nov 27, 2006 | 10:47 PM
bondoboy's Avatar
bondoboy
Default dumb gas tank question
I have a 71.
See picture
Are these gas tanks prone to rust on top? I put a new cap on it and I keep a weatherproof cover on the car. I was doing some work on the carb and found water in the system. I siphoned about 2 gallons of water from the tank. The drain was a little plugged up, but I can't see how that much got in. I don't smell gas around the tank area so it can't have much of a leak. Please give me any ideas before I decide to lower the tank. If I would need a tank, who makes the best one? I want one made in USA or Canada, no taiwan or china. Thanks a lot.
Marty
Old Nov 28, 2006 | 01:04 AM
Hammerhead Fred's Avatar
Hammerhead Fred
If the overflow neck is properly installed and the drain leading from it is plugged then you can indeed get lots of water in the tank from a good sized rain storm. Don't know how you'd get it in there with a full-time cover on the car though.
Old Nov 28, 2006 | 06:27 PM
bondoboy's Avatar
bondoboy
The company said the cover was weatherproof, but I always see some water under it after it rains. I blew out the drain hose and I'll see if that fixes it. Thanks for the help.
Old Nov 28, 2006 | 06:39 PM
jpatrick636's Avatar
jpatrick636
It could have been from the gas station. If you happened to draw from a nearly empty tank, there is always water in the bottom of them. It would not be the first time it ever happened!
Old Nov 28, 2006 | 08:08 PM
wombvette's Avatar
wombvette
Knock that whole plug out of the drain and it will solve the problem. This stupid little drain line has ruined a many gas tank.
Old Nov 28, 2006 | 09:38 PM
bondoboy's Avatar
bondoboy
I don't know about the water coming from the gas pump. I drove it a lot without any problems. The problem came when it sat a while due to an ignition problem. Where is the plug I should remove? All I have is a hose coming from the gas cap area hanging down behind the license plate. Was there something in the end of the hose originally? Thanks again.
Old Nov 28, 2006 | 10:39 PM
Hammerhead Fred
I don't know that I'd remove the plug and drain hose from the overflow neck. It's not there so much to redirect rainwater away from your gas tank as it is to safely give gasoline spills a safe path to the ground should you manage somehow to miss the getting the gas into the tank.
Wouldn't want to spill gas on top of your gas tank and then have it run down all over your hot mufflers at some future fill-up would ya?
Sounds like your hose is properly installed if it drains out from under the bumper. I'd simply force some water down it using a hose to clean it out and ensure it is draining well.
Still doesn't sound like the source of your water issue though (based on your description). Two gallons of water is A LOT! Sure you didn't just need to siphon off two gallons of mostly gas before you got all the water out? I'd just keep an eye on it at this point and, if it should happen again, it's way easier to simply disconnect the lower fuel line from below the tank and let it drain into a fuel can using a piece of fuel line.
Old Nov 29, 2006 | 12:10 AM
wombvette's Avatar
wombvette
I knock the pipe off of every one that I have, and I havent burned one up yet. I have seen many come though my shop with rusty leaking tanks that are pouring gas down on the spare tire and the mufflers though. Those rusted tanks caused by the water that came from those stopped up drains. So chose your poision. Which one is more dangerous.
Old Nov 29, 2006 | 12:50 AM
bondoboy's Avatar
bondoboy
I think I will make sure the drain is clean and keep an eye on it. If I continue to have problems, I will try one of the other suggestions. I don't know how that much water got in there, but there was a lot. I had to siphon a lot out before any gas came out. If I would need a tank, who makes the best ones? I want a USA or Canada made tank, no taiwan or china. Thanks a lot.
To dumb gas tank question
By Michael S. Palmer | 2026-06-03 11:00:24
