Brakes
Old Nov 28, 2006 | 10:24 PM
jamesc1123's Avatar
jamesc1123
Default Brakes
I recently replaced the seals and pistons on all of my calipers. There's no more leaks, but now I depress the brake pedal fully and I'm only getting meager braking. Any ideas?
Old Nov 28, 2006 | 10:44 PM
SIXFOOTER's Avatar
SIXFOOTER
Bleed em some more, theres bubbles in there
Old Nov 28, 2006 | 11:02 PM
JoeRags's Avatar
JoeRags
Old Nov 28, 2006 | 11:13 PM
greyghost79's Avatar
greyghost79
Old Nov 29, 2006 | 07:03 AM
jamesc1123's Avatar
jamesc1123
I've heard it both ways: bleed LR, RR, LF, RF or start closest to the MC and work your way out. What is the best solution? Also, if I did in fact happen to let the fluid fall too low, what are the consequences?
Old Nov 29, 2006 | 09:11 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
IMHO, the order is'nt all that important, you should do each caliper multiple times anyway so what ever order is moot.
If you let the MC run dry you have to bleed the MC again. DON'T do it!
Old Nov 29, 2006 | 10:57 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If time is not an issue, try gravity bleeding. I've done it for years with many Vettes and have never had a problem. I try to do it every 2 years to keep the fluid fresh and just start at the LR, then RR, then LF and finally RF. I usually take a cup or so from each caliper. Again, this is slow but it works for me. As stated above, keep your eye on the MC as you want to keep it from running dry and introducing air inlto the system.
Old Nov 29, 2006 | 11:15 AM
Durango_Boy's Avatar
Durango_Boy
That is the correct bleed sequence. Doing it the other way will leave air in the system. You will always want to go around twice. Sometimes I do it three times just to be sure. No air = Nose stand braking.
Old Nov 29, 2006 | 11:29 AM
Jud Chapin's Avatar
Jud Chapin
I stand corrected. I just checked my GM shop manual and it states that whether bleeding the front or rear, bleed the valve nearest the MC first. "This sequence expels air from the lines and calipers nearest the MC first and eliminates the possiblility that air in a line close to the MC may enter a line farther away after it has been bled".
Old Nov 29, 2006 | 11:32 AM
Durango_Boy
Good to see it in writing...
Old Nov 29, 2006 | 11:35 AM
Jud Chapin's Avatar
Jud Chapin
Funny, I've been doing it farthest from the MC for many years and never had a problem. I'm going back and change my other post to show the proper sequence so that someone doesn't get screwed up.
Old Nov 29, 2006 | 11:37 AM
Durango_Boy
It's pretty easy if you always start from the LR, and go counter clockwise.
Old Nov 29, 2006 | 11:39 AM
Jud Chapin's Avatar
Jud Chapin
Right you are!
Old Nov 29, 2006 | 07:32 PM
Durango_Boy
Right you are!
I can't believe how much trouble a few tiny bubbles cause in the system. It bugged me for years in one of my other Vettes and I swore to never let my brakes feel like that again...it's for that reason I have switched to Hydro.
Old Nov 29, 2006 | 10:01 PM
motovate's Avatar
motovate
With front and rear brake systems separate it would seem that each needs to be bled separately - probably caliper closest to MC first either front or rear but finish one system - front or rear - first then move to the other system????????
LBM
Old Nov 29, 2006 | 10:06 PM
Durango_Boy
LBM
That's what we're meaning. I preach to always start on the driver's rear first. That's a rear system. Then, move over tot he passenger rear to finish the rear system. Then, move up to the passenger front, starting the front system. Finally, moving over to the driver's front, finishing that system. I also recommend doing the whole procedure twice, and maybe even a third time if all lines, and calipers were dry to begin with.
Old Nov 29, 2006 | 11:35 PM
jamesc1123's Avatar
jamesc1123
Alright, I think I'm going to bleed those calipers through a good half gallon of brake fluid as soon as I get a chance. Thanks for the help.
To Brakes
Old Dec 1, 2006 | 02:35 PM
motovate's Avatar
motovate
Not arguing here but wondering why it makes a difference which system first. Everyone seems to start in the rear but if they are seperate systems it wouldn't seem to matter which system gets bled first - just that all the air is out.????
LBM
Old Dec 1, 2006 | 02:49 PM
Durango_Boy
LBM
I really don't know the answer to that. I just know that I have tried both ways, plenty of times. I always had much better luck starting with the rear system first. Seems to do a more complete job of purging the air.
Old Dec 1, 2006 | 03:14 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Here's a trick,..if you're still getting small bubbles after what should be enough time to purge the system of air, put some grease around the bleeders to prevent air from being sucked past the the bleeder threads when they're opened.
