Ditching the Crossfire
I'll post up specs later if I remember or PM me to remind me. The heads suck, the cam is like a flippin broom handle. Half of my xfire crap was shot so that's why I choose this route. For $1600 and my labor I am looking at a HP increase of 150 or so. We will dyno and see.
Best to you, please keep us posted and we can compare notes
tt
Pick your goal and build your motor around each component, DO NOT just pick and choose, make an educated decision on your parts.
Already starting-out with 9:1 compression with 76cc heads, so smaller 64cc heads will raise CR to approx 10:1, still low-enough for most pump-gas:
keep the RPMs below 5500 with the OEM bottom-end, and you'll make enough smoke to trash the 700R4, or pitch the Dana-44 if you ever hook it up.
What brand torq converter are folks using on the c-3, 80 vintage? In the 2000 stall range?
tt
I'm considering a new cam for a winter project, what would you guys recomend? Also, at what power level can I expect the 700r4 to give way?
I am going with the comp cam listed below, should perform well, HP and torq, not too extreme, more on the bottom end as cams go, but give a pretty good muscle car lope at low idle. This cam will work with stock heads.
Camshaft Specification Table
Part Number 12-210-2
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 268H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.454 0.454
Duration At 0.006 Tappet Lift 268 268
Valve Timing At 0.006
Open Close
Intake 28 60
Exhaust 68 20
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 218
Lobe Lift 0.3026 0.3026
Lobe Separation 110
Heres the basics to help improve a crossfire in the above quote. Crossfires are really good systems but supported by low HP OEM parts or pieces. Put some *** in the engine and the crossfire will come to life! There like the crossram from the early Z28 Camaros.
