427 or 454?
Old Nov 29, 2006 | 02:27 AM
brentcarl84's Avatar
brentcarl84
Default 427 or 454?
Ok so right now i have a 350 in my vette with a 3 speed tranny. I'm looking at replacing it this spring with a 427 or 454. What would you recommend and what's it gonna take?
Old Nov 29, 2006 | 02:59 AM
PRNDL's Avatar
PRNDL
The only 427 I know about is the LS7, which would be a great choice, but you might want to try one of the 454 crate engines.
Old Nov 29, 2006 | 03:28 AM
ikwhite's Avatar
ikwhite
Default Hmmm
I dont want to hijack your thread here or get to far off topic but I have been pondering the same sort of thing about going to BB and ran across these mini rat SB as yet another option to the 427/454 BB and thought I would pass it along just in case you might be interested.If your set on a BB just ignore me
http://www.hotrod.com/techarticles/4..._block_review/
K
Old Nov 29, 2006 | 07:08 AM
markdtn's Avatar
markdtn
Do a search on Big Block swap, it's been done many times. But if I was going to go to the trouble of a swap, I'd swap in an LSx engine.
Old Nov 29, 2006 | 07:40 AM
L88Plus's Avatar
L88Plus
If you don't end up buying a complete engine and building your own, go 496. Cranks, rods and pistons cost the same, might as well get all the cubes you can. Then all you have to get used to is your eyeballs pressed against the back of your skull!
Old Nov 29, 2006 | 07:49 AM
wfo76's Avatar
wfo76
The LS7 was a 454 released only in crate form but the 12 to 1 compression was too much for today's gasoline.
Go with the cubes, 468 or 496
Old Nov 29, 2006 | 08:23 AM
shafrs3's Avatar
shafrs3
The blocks weight the same, go with the big one. Another way you could think of it is if you wanted to replace you small block you probably wouldn't consider a 327.
As far as what it will take, you'll have to round up the necessary pulleys and brackets unique to the Vette. The biggest odd ball pulley is for the water pump, it's a 3 grove unit. If I were considering this swap I'd be pricing an after market serpentine solution. It might be cheaper than original equipment parts.
Glensgages's Avatar
Glensgages
..... other-than financial-considerations, why use displacements determined 30+ years ago?
As stated above, the 496, or even the 502CID/502HP/567TQ crate-engines, offer more power for less work (RPM ), and would give unsuspecting C5/C6 owners a surprise!
Old Nov 29, 2006 | 09:29 AM
norvalwilhelm's Avatar
norvalwilhelm
For the street a 454 will outpull a 427. In identical set up engines the 454 puts out 25 more horse then the 427 but why stop with a 454. Use the block and put in a cheap stroker crank, the only custom part of the 496. Pistons cost the same, same cam, same everything except for the 1/4 inch stroker crank.
A 496 is really a big step above the 454 and certainly a long way above the 427. A mild oval port 496 can easily put out 600 horse. This is from Lenginfelter.
Guys I don't read other replies before jumping in so if I said the same thing as already posted it means I agree. I like to give my un biased opinion and then go back and read what others have said.
L88 I see already said the same thing.
Old Nov 29, 2006 | 11:49 AM
BigBlockk's Avatar
BigBlockk
There are a lot of people that think that more is better. While lots of horsepower is fun, you also have to live with this beast you've created. Truly big inch Small Blocks can cost a great deal to build. Out sized Big Blocks can be very temperamental in every day use.
The rear suspensions in these cars can't hook up 400 HP let alone 600 or 700. Without spending a lot of money that is. Once the rear tires start smoking it's all good. A will built 427 can easily top out at 160 to 170 MPH. The L88 cames to mind here.
I think it would be neat to have "427" on the hood of a rubber bumper car.
BigBlockk
Later.....
Old Nov 29, 2006 | 12:22 PM
bence13_33's Avatar
bence13_33
This is not true, my rear suspension is completely stock except for my rear leaf spring and I have no problem hooking up at the track with 28x11.5x15 ET Street tires and my motor was putting out around 500HP. As for MPH that is more of a gearing issue. My car will probably tap out around 130MPH (redlined in 4th) but it will do 120+ MPH down the 1/4 mile.
As stated above go for as many cubes as you can afford. I wish I could do it all over again because I would have spent my money on a 540 (that is the next motor I am going to build). A 496 costs roughly the same to build as a 454 or 427 so I would go at least 496 no real reason to go any smaller. Cubic inches are easy horsepower.
Old Nov 29, 2006 | 07:28 PM
BigBlockk's Avatar
BigBlockk
When I first got my '70 it would freely spin the tires for 80 to 100 feet. This was with a stock 390 HP 454. Now, it is true that I could have gone to a long duration cam and killed some low speed torque but then the car isn't as versatile. Wayne Nelson could come off the line at full throttle and not spin the G70's on his '69 L88 and it had 650 HP. Like I said in my other post, if you want to spend enough money and make a perfectly balanced car, then, yes the rear suspension can take more power and hook up well. But once the rear tires are spinning it doesn't matter if your spinning them with 400 HP or 1000 HP. their still spinning.
A well built 427 or 454 will activate the pucker reflex in most people. Building much more than this will add little to the fun factor and a lot to the annoyance factor.
I don't know, I guess I'm mellowing with age.
BigBlockk
Later.....
Old Nov 29, 2006 | 08:19 PM
andylmusic76's Avatar
andylmusic76
this is what i heard about these two engines (i was looking into doing the same swap).
i think the 427 is the better overall for torque and horsepower (it's power to weight ratio).
but my buddy will be putting a 454 into a 73 camaro. the 454's are the much better choice for forced induction purposes, the 427s are not. but simply for natural aspiration, i think the 427 may be better. i also thing the 454's run hot in the vettes (can't say for sure though, but check into it).
my .02 cents
Old Nov 29, 2006 | 08:31 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Since you have an automatic, I would go with a 454 or a 502 crate motor.
the 427 is a good motor for a revv monster big block. the 3.766 stroke and the 4.25 bore make for a create high RPM beast. Unless you already have the parts, go with the 454 or a 502.
A ZZ502 crate motor will rock all day.
Old Nov 29, 2006 | 10:00 PM
shafrs3's Avatar
shafrs3
I like my 496, and it hooks fine, doesn't overheat either.
Old Nov 30, 2006 | 09:16 AM
KJL's Avatar
KJL
This what I did but it was not cheap!! A crate big block would have given me more bang for the buck.
Old Dec 1, 2006 | 01:30 AM
ikwhite's Avatar
ikwhite
So are you saying that if you had to do over again you would go with a crate big block 427/454 ?
K
To 427 or 454?
Old Dec 1, 2006 | 08:00 AM
KJL's Avatar
KJL
Yes. A big block will give you more flexability as well. Big inch small blocks are limited by the heads. I can never put any kind of forced induction on my engine because I could never get my CR low enough because of the limited combustion chamber sizes in small block heads. Don't get me wrong, I like my set up but in hind site I would have given much more consideration to one of those big inch big blocks. We could discuss for days how much HP is to much HP but torque is where the fun is and HP is where the bragging rights are. In five years after you install your new Whipple screw type blower you may decide to fine tune your suspension to handle the 800 hp and extra wide drag slicks hanging off your offset trailing arms.....who knows...right?
Old Dec 1, 2006 | 08:45 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
"427"
ZIXXX PACKER
Old Dec 1, 2006 | 10:00 AM
fastpig's Avatar
fastpig
Bigger is better! I started out with my 72' and the stock 350. A short time later came the 383 but after a little nitrous incident, along came the big block. I built an aluminum headed 427 monster. On motor it ran 11.3 @ 125 mph, on the nitrious it ran 9.9 sec. @ 140 mph. That was a fun ride!!! But after another small incident with nitrous, you'd think I'd learn, it's now time for the next engine. If I had the money I'd go with a 572 crate motor and be done with it. Speed is addictive, what ever you build will soon not be enough and you'll wish you went bigger. So go as big as you can afford !
