I dont know a lot its just the mark on the balancer is right on the timing mark I belive it is at 0. Does this mean I need to advance it more?
This means that the engine is at Top Dead Center. Your timing should be set at about 8-12 degrees before top dead center (without any vacuum advance). If you are at Top Dead Center (TDC), the engine is firing after it is supposed to, causing your backfire. You need to move the distributor cap until you are at 8-12 degrees before TDC.
depends really on what kind of timing light he is using. If for example he is using a dial back timing light and it's set on the dial at 12º and his timing is actually at 12º than the line on the balancer will be aligned with the "0" index mark on the index plate which means the timing would be dead on.......
If he is using a non-dial back timing light and the marks are aligned at "0" than the would would be at TDC and therefore too retarded.
Maybe the original poster will reply back to what type of timing light he is using, whether it's a regular light or a dial-back light.
Wish I knew what kind of timing light is there any wat to tell?
Does your timing light just have the gun, with a trigger, power cable, and impulse cable? If that is all it has, it is just the standard timing light. If it is adjustable, with a dial or digital screen or something like that, then you have a dial-back timing light.
If you still aren't sure, can you post some pictures?
I guess its standard it just has a hot a ground and a lead for #1 plug wire.
wiring will be the same for all types......
look at the light itself - does it have a dial on the back or a digital display.
As an example, here is a popular dial back model so you can see the dial on the back
