I'll soon be going with a Keisler 5-speed and also plan to have the rear end rebuilt, at which time I'll be able to select any gearing I choose. I currently have a 3.36 gear. I asked the Keisler rep and he suggested the TKO-600 and a 3.73 gear.
Who is out there running a TKO and what rear gears are you running? Impressions? Just looking for some more info to base a decision on.
If you remember Project Shark Attack from Corvette Fever Magazine over the past year and a half, we the rear was rebuilt 3.70's were put in, but most of us found that it made 1st gear too steep; red lined (6000rpm) at 30mph. We went back to the 3.36's that came with the car and things improved all around. There was more than ample torque available. 3.08's would certainly work, but the 3.36's seemed best in that application.
I have a Kiestler TKO600 with a 3.26 1st gear and the 0.81 5th gear. $2200 to anyone who is interested, it is the "Direct fit" model with the offset shifter location.
The 3.27 gear will greatly improve your acceleration and give you plenty of o.d.
One of the things I always tell my customers is try what you have you can always go down in rear gear later.
We have a 65 vette with a Ramjet 350/380 hp 3.73 and the TKO-500
it really screams in 1st and it's a lot of fun. That would probably be to low for most.
I had considered that, and without rebuilding the differential it's likely how I'd go. Since my differential has alot of play in it and is also leaking, I figured I'd look for the "ideal" combination, since it's easy enough to put any set of gears into it during the rebuild of the diff. To that end, I guess the real question is, "If you were replacing the differential and getting a TKO at the same time, which combination would you choose and why?".
A loaded question to be sure, but just looking for as much information as I can get to help me reach a decision.
Thanks for all the responses, keep them coming!
Hello, Ive got a 3.36 rear with a TKO-500 and a .64 overdrive. I agree with Gene as a great over all combo, great first low and 5th is a little above idle at 70!!!! Or on the other side of things ,how much top speed can you handle!!!! 5500-6000 rpm in overdrive ( .64) CAN YOU SAY WAY PAST 160 ON THE SPEDO!!!!!! This is a good set up if your HP is bellow 500.
"since it's easy enough to put any set of gears into it during the rebuild of the diff."Thanks for all the responses, keep them coming!
Not quite true as you are limited by the carrier. A 3-series carrier will accept standard GM Corvette gears up to 3.70 (maybe 3.90 from the aftermarket). (No such thing as a 3.73:1 from GM for C2-C3 Corvettes.) To move up to a 4:11 or higher, you would need to install a 4-series carrier, or possibly find something that could work from the aftermarket.
Not trying to be a smart azz, just in case you didn't know.
Not quite true as you are limited by the carrier. A 3-series carrier will accept standard GM Corvette gears up to 3.70 (maybe 3.90 from the aftermarket). To move up to a 4:11 or higher, you would need to install a 4-series carrier, or possibly find something that could work from the aftermarket.
4 series gears are readily available now that fit a 3 series carrier. They just use a thick ring gear.
I run a 3.70 gear in my TKO 500 and Ithink this is a great gear. My motor does not make a lot of low end power so driving at 65 at 1200 rpm would not fly. I cruise the highway at 2200 to 2300 at 70+ mph and it is very smooth. You have to consider what power band your motor has. The newer FI motors makes gobs of low end torque so they can cruise at 1200 rpm all day. If you are cammed for low end torque a 3.36 or 3.08 is OK. If you are cammed with considerable duration you need more gear.
Good point. I hadn't planned on moving outside a 3-series gear but didn't make that clear. I should have said that just about any other 3-series gear would work during the rebuild.
I just got my TKO-600 and will be getting my diff back tomorrow. I had it rebuilt with 3.70 gears as Gene suggested. Sounds like it's a good way to go. The gears aren't cheap nor is the rebuild so I thought long and hard about it and chose the 3.70's.
Just an update, I put a call in to Gene at Keisler today, ordered the TKO-600 (.64). I'm also looking at my options for having the differential rebuilt, including using forum member GTR1999. I liked what he had to say and I feel I couldn't do much better (if at all) with anyone else. If he does the rear end, I'll likely have him throw in 3.73's as it seems to me to be the best match for the new tranny, and it's what he said he'd be using instead of 3.70's.
C3Bob76
I think the first thing to consider is where your motor likes to cruise. Once you know what the best torque range is and where you get the best fuel economy you would use a rpm calculator (found on ours and other sites) to pick an overdrive ratio that when combined with your tire size will put you at the rpm you want at the speed you want to cruise at. Fuel injected engines have a computerized management system that will allow lower rpm cruising without wasting fuel and loading up the engine so you can get away with cruising at 1200 rpm at 70 mph. Carburetors are not capable of runing at the wider ranges and stock or close to stock setups usually like it at about 1800 ish to 2300 rpm. Anything lower than that will waste fuel instead of saving it which besides lowering high engine rpm is why you have an OD tranny to begin with. Every engine is different and every driver has a different expectation of what he or she likes. Most people can usually tell what RPM their engine like to cruise. I would shoot for that rpm with your present rear gear and see first gear suits you. Not too low and not too high. You can always change the rear gears later. My first choice though would be 3.73's and the TKO 600 with a .64. 2150 RPM @ 70 mph with 26" tires.
